HELP please!!!!!brakes
Old Apr 24, 2012 | 02:47 PM
93pearlvette's Avatar
93pearlvette
Default HELP please!!!!!brakes
I have a 93 corvette we have been restoring for a few months,we are finally done,every time I drive the car after about 2 miles all 4 wheels lock up...we have bleed the brakes and not helping and we heard just leave valves open and let lines gravity feed,but front brakes are not getting any fluid to them.....
Car has been sitting up for 11 years,has 73k miles...
Please help any input apriciated,
Old Apr 24, 2012 | 04:14 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
Not sure what you mean by "all 4 wheels lock up". Do you mean they start binding when warm, or that when you step on the pedal all 4 wheels skid (or activate the ABS)?
Also, when you bled the front brakes, you say you're not getting any fluid to them. Meaning... nothing comes out the bleed valve, or it's not pushing the piston?
Regardless, I don't think further bleeding is going to resolve your problem.
Old Apr 24, 2012 | 09:15 PM
richauto's Avatar
richauto
Try pushjng the caliper pistons in,if they do not go in easily try disconnecting the brake hose, if they now go in you have a bad brake hose. Good luck
Old Apr 24, 2012 | 10:14 PM
desertmike1's Avatar
desertmike1
Could also be corrosion in the calipers causing the pistons to bind up possibly!
Old Apr 24, 2012 | 11:54 PM
93pearlvette
Thanks for all the suggestions,kinda thought it might be the calipers having corrosion also,I do live on gulf coast so even though it was in garage was still in humidity,so I ordered all new calipers,will be here tomorrow and will post if that works or not.
To HELP please!!!!!brakes
