Code for "sport" steering rack
Old Apr 25, 2012 | 05:45 PM
StealthLT4's Avatar
StealthLT4
Default Code for "sport" steering rack
I'm looking for a sport-ratio steering rack (2.0-turn), and am having trouble. The only one I can find is on eBay, and is for 84-87, whereas I need one with the 88-96 inner tie rods. There are more racks advertized, but they just list "codes," not a ratio, or whether it is sport or not.
Does anyone know the code of the 2.0-turn steering rack? The codes I've seen on ebay are: NS, YR, AJ, AK, YP, and FH.
Also, I may have to resort to a remanufactured rack from Autozone/others. They advertize 2 1/4 turns. I've heard a lot of people commenting about how the 2 racks aren't really 2.0 and 2.5 turns; so is 2 1/4 the quick or slow? Thanks for the help guys.
Old Apr 25, 2012 | 06:19 PM
aminnich's Avatar
aminnich
I don't think you can get a 2.0 to fit a 96.
Old Apr 25, 2012 | 08:07 PM
StealthLT4's Avatar
StealthLT4
Is that due to the inner tie rods or the intermediate shaft attachment point? I know they made quick-ratio racks after '87, so getting the right inner tie rods should make that OK. Doing research I found some mention of differing intermediate shaft points, but no mention to when it changed or what years were compatible. When I replaced my intermediate shaft a year or so ago, I think it was sold as a 84-96 part, too.
Old Apr 27, 2012 | 01:04 AM
Cliff Harris's Avatar
Cliff Harris
The suspension changed quite a bit in '88. I know they eliminated the fast ratio rack on later C4s, but don't know when that happened.
Maybe these guys can help you out:
http://www.turnone-steering.com/
Last edited by Cliff Harris; Apr 27, 2012 at 01:06 AM. Reason: Added Turn One link.
Old Apr 27, 2012 | 01:41 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
In the early models the fast rack was a component of the Z51 package.
Those racks are difficult to find in the aftermarket.
Best bet is pulling one from a salvage.
Old Apr 27, 2012 | 08:36 AM
shakedown067's Avatar
shakedown067
St. Jude Donor '12-'13
I ordered an '89 reman Z51 rack for my '96. All Z51s from 89 to I believe 92 have the sport rack that fits. No clue on the code for it. Bolted right in. I've only seen them listed as standard and sport, with sport being the quick ratio. You certainly want an '89 or newer rack.
Old Apr 27, 2012 | 11:44 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Send your OEM unit to the guys at Turnone and have them rebuild it for you.
Old Apr 28, 2012 | 10:22 PM
C4boy's Avatar
C4boy
Stealth, if I'm not mistaken those codes refer to the letters stamped into the housing on the rack. But I don't know what they actually designate. I'd contact one of the rebuilders on ebay and see if they can give you some info on the differences. Rebuilt 2.0 turn sport racks are very difficult to find. The only reasonably priced ones I founds were from a couple rebuilders on ebay.
Old Apr 29, 2012 | 10:18 AM
StealthLT4's Avatar
StealthLT4
Thanks guys. I know the model years the racks were available and the one I want; just trying to correlate that to the code on the rack. I guess I will try contacting them.
Old Apr 29, 2012 | 02:24 PM
milsurpman's Avatar
milsurpman
My 89 z51 is equiped from Bowling Green with the Fast rack which is Code Ns per the build sheet. Im not sure if the housings are the same between the slow ratio and fast. I would definitely make sure a rebuild at some vendor didnt turn it into a hybrid as far as ratio goes due to hard part changes.
Old Apr 29, 2012 | 05:16 PM
StealthLT4's Avatar
StealthLT4
Thanks! That's definitely one of the codes I've seen.
Update: I found a seller advertising 84-92 reman racks, available in 2.5 or 2.0-turns. Did anything happen in 1993? I'm thinking its just confusion on the seller's part (and I shot him an email about it), but am I missing anything? I found a couple of similar ones, and I'll post them as soon as figure it out and buy one
Old Apr 29, 2012 | 06:23 PM
C4boy's Avatar
C4boy
I'm pretty sure GM made 2.0, 2.25 and 2.5 turn ratio racks for the C4. Different inner tie rods would also make the overall rack part # different through the years, while the rack could still be the same for more years than advertised (just a guess). I thought the sport rack option became standard on all '96s? If that's the case, you already have a sport rack by default, though I don't know the ratio.
Old Apr 29, 2012 | 08:59 PM
milsurpman's Avatar
milsurpman
I checked my Gm parts manual. It appears the inner tie rod on the rack changed part numbers in 93 and ran through 96. What the change is to the inner tie rods I dont know. I always thought the core front suspension was the same from 89-96. Hopefully someone who has done the conversion on the post 93 will jump in and add some info.
Old Apr 30, 2012 | 08:38 AM
shakedown067
All racks from 89+ fit an 89-96. My steering certainly improved adding the sport rack to my '96.
Old Apr 30, 2012 | 08:04 PM
StealthLT4's Avatar
StealthLT4
Just bought one! Found 2 sellers offering remanufactured racks. Here's the one I got. $304 with free shipping, and a $140 refund if you send back your core (effectively $164 including shipping; that's pretty good!). The seller confirmed that fitment did not change between 88 and 96, so I will be getting a 2.0-turn rack in 96 fitment.
http://www.ebay.com/itm/290704664277?ssPageName=STRK:MEWAX:IT&_t rksid=p3984.m1438.l2649
And here's another one, slightly more expensive ($186 after core trade-in), that's still available:
http://www.ebay.com/itm/400255314375?ssPageName=STRK:MEWAX:IT&_t rksid=p3984.m1438.l2649
Old May 1, 2012 | 10:11 AM
shakedown067
Nice, I think I paid $180 for mine. Now you'll get to enjoy installing that bad boy. LOL
To Code for "sport" steering rack
