84 c4 stalling problems
Old May 3, 2012 | 04:56 PM
oquail's Avatar
oquail
7th Gear
Default 84 c4 stalling problems
hi i have a 1984 c4 automatic with cfi when i hit the gas real hard taking off at a light it'll sputter and die although sometime i can save it but if it does die i have to have the key on and pull the fuses for the injectors and then put then back in and it'll fire right up an if i don't you can sit there crankin it until the battery dies an it wont fire. If anyone knows what is causing this and how to fix it, it would be greatly appreciated, and thank you for all of your help.
Old May 3, 2012 | 06:46 PM
nutz4c4's Avatar
nutz4c4
ghytgbhgtyygbvffr?????
Old May 3, 2012 | 06:55 PM
dukeallen's Avatar
dukeallen
Old May 3, 2012 | 07:16 PM
Vette Jockey's Avatar
Vette Jockey
Roadster Madness. 😠
St. Jude Donor '13, '20-'21
Old May 3, 2012 | 07:34 PM
oquail's Avatar
oquail
7th Gear
no one has any idea? could it be a wiring problem? could it be an injector problem? i could really use some help. when the care is running it runs good
To 84 c4 stalling problems
