GM White Paint Code 40 WA8554 Issues!
Old May 8, 2012 | 01:10 PM
jfcalvarese's Avatar
jfcalvarese
Default GM White Paint Code 40 WA8554 Issues!
So i'm doing some touch-up paint work on my 1985 Coupe A/T. I special ordered 4 spray cans of "Dupli-Color Perfect Match Automotive Paint" from Napa that were supposed to give me an exact match for the white on my car. Unfortunately, Dupli-Color's attempt at matching GM White Code 40 WA8554 was poor to say the least. The color that came out on my test area was a light cream color, most definitely not a pure white like the paint is on my Vette.
So my question is: has anyone else ever run into this problem or one similar? GM Paint Code 40 WA8554 is supposed to be a pure white, not an off-white cream color, correct?
I'm worried if I try Rustoleum's or Automotive Touch Up's automotive spray cans , I may run into a similar problem.
Old May 8, 2012 | 01:29 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
They had a lot of problems in the early C4's with paint fadeing, discoloring and deterioration in both their base coat - clearcoat and single stage paints. Depending upon the overall condition of your paint, you may be able to go to an automotive paint store and have them try a color match and paint put in spray cans.
Old May 8, 2012 | 02:01 PM
Old Ben's Avatar
Old Ben
2017 C6 of Year Finalist
I bought a bottle of Arctic White touch up paint that had aged. It came out the very light buff color. Took it back and made sure the replacement one was current and it did match when applied. Could be that they had those cans for quite a while.
Old May 8, 2012 | 06:15 PM
jfcalvarese
I checked the batch dates, they are definitely current cans, made in 2011.
My only question as of now is: is GM White 40 WA8554 supposed to be a pure white or an off white (light cream)?
My gut instinct is telling me that it IS supposed to be a pure white and Duplicolor just messed up and I should order a can of the same GM paint code from automotivetouchup.com. Further thoughts or suggestions?
Old May 8, 2012 | 10:05 PM
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
AS far as I know the GM Paint Code 40 W was only used on the 35th Anni and some Caddys. My 35th is a light cream color and as far as I can tell it has the original paint.
Old May 8, 2012 | 10:18 PM
VetteMed's Avatar
VetteMed
I just had some paint mixed for my white '91 ZR-1 (arctic white), I think it was WA9567. Local body paint supply store mixed it, it's a perfect match. I threw away several bottles of that duplicolor crap, which was way too cream/off-white colored.
Old May 8, 2012 | 10:24 PM
jfcalvarese
http://paintref.com/cgi-bin/colorcod...rn&sname=White
As you can see from the above link, many GMs used Paint Code 40 W8554.
Interestingly enough, Saturn's 40 WA8554 is a "cream white"
http://www.paintscratch.com/touch_up...40-WA8554.html
Same website, same GM paint code, for 1985 Corvette. Different color...
http://www.paintscratch.com/cgi-bin/makepaint2.cgi
I think Duplicolor is using GM's Saturn paint code 40 WA8554, which is cream white, not Chevy's paint code 40 WA8554...
Ideas?
Old May 9, 2012 | 08:37 AM
jfcalvarese
I thought the 35th Anni was supposed to be triple white, not double white with cream or triple cream?
Also, GM paint code 40 wa8554 has been used on hundreds of different cars and is still used today according to paintref.com, which makes me think its not cream?
Old May 9, 2012 | 12:28 PM
BSenzina's Avatar
BSenzina
I have an 84 and used the Arctic White when I repainted it. ITS AMAZING...especially after a couple of red accents
Old May 9, 2012 | 12:32 PM
Z51JEFF's Avatar
Z51JEFF
The white on the early cars is an off white with a slight cream look to it,looks nothing like the latter Arctic White.
Old May 9, 2012 | 03:24 PM
jfcalvarese
Ok, this would make more sense. It appears my paint code WA8554 was used on Corvettes from 85-88, then again in 2001-2003 (mine is an 85 again). My final conclusion with what you said in mind is that my car must have been resprayed at some point in its life because it is pure, bright white currently. I can also see what appears to be a layer of paint under my current top coat that looks off-white/creamish. This may just be primer? Or the original paint color!
Now I just have to hope that whoever sprayed it used some common sense and sprayed it with Arctic White, so it ill be easy to get...
http://paintref.com/corvette/white_corvette.shtml
Old Jun 19, 2012 | 11:58 PM
JMellor's Avatar
JMellor
3rd Gear
Default Pearl White
the 40 color is Pearl White, like most years, my 1992 Triple White is Artic White and while there is confusion out there regarding this, there is no mistaking the color difference.
Old Jul 11, 2012 | 02:40 PM
QIK59's Avatar
QIK59
Arctic White is not GM Code 40.
I believe Arctic White is GM Code 10.
Arctic White is also GM 153 , WA 9567.
Code 40 IS a creamy white.
Code 10 is more a "true" white.
I will confirm shortly which one better match's my Polar, Classic, Can-Am & Porcelain GM # 153 White painted car when I attempt to touch-up with genuine GM Code 40 and Dupli- Colour GM 153 brush touch-up paints.
Old Dec 10, 2012 | 02:08 AM
JMellor's Avatar
JMellor
3rd Gear
Paint Code 40 is Pearl White and is affected by the quality of the mix done.
Paint Code 10 is Artic White and it is bright and schweet, also less likely to have mis-match as it is purer.
Old Dec 10, 2012 | 04:48 AM
Z51JEFF's Avatar
Z51JEFF
Pearl White was never used on a mass produced Corvette.Ive seen one late 80s car in Pearl White but was told this wasn't a production color on alot of cars.
Old Dec 11, 2012 | 06:12 PM
LT4 F45's Avatar
LT4 F45
Early C4's and 35th are more cream looking than Artic White late C4's
Old Dec 12, 2012 | 02:31 PM
professorX's Avatar
professorX
first off let me tell you coming from an autobody painter ANY sort of paint touch up will NEVER match because of many factors, including old faded paint, touch up paint is a single stage process negating the basecoat clearcoat factory finish and there are way to many varients with white paint. If you were to bring your car into any respectable body shop and for example say you just wanted the rear quarter panel repainted they would tell you it will not match because they would want to blend into the door and prob the rear bumper, what I am trying to say is white is a pain in the ***.
To GM White Paint Code 40 WA8554 Issues!
Old Dec 12, 2012 | 05:20 PM
ejscarfo's Avatar
ejscarfo
White is one of those colors that will fade and be hard to match, even if you think the paint is in excellent shape. I've gone through this with 2 white cars I had. That being said, the Duplicolor should be a close match, especially once the clear coat is added. I normally get my rattle cans made with Sherwin Williams paints and so far, its been a hit every time, even 3 stage Caddy paint.
Old Dec 12, 2012 | 09:11 PM
WVZR-1's Avatar
WVZR-1
Code 40 white is/was one of the more/most miserable colors to match in the mid to late 80's. It was one of GM's ventures using different product in different assembly plants. I don't recall how many "advertised" variants there were but I remember the "revolt" from an insurance company when I asked to be paid for the "test panels" that I felt were going to be needed for a larger job that neither I or the owner wanted to blend for a best match. In the 80's I had 3 code 40 cars and the paint was a "variant" on all three.
Old Dec 12, 2012 | 09:30 PM
tpfarm's Avatar
tpfarm
If you can finally figure out the proper color , I have had excellent results on my Polo Green Vette and my wife's 1967 Mercedes 230 SL by using www.automotivetouchup.com
