Waterpump?
Old May 30, 2012 | 01:50 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
Default Waterpump?
Looks like this weekend I'm changing or at least checking closely my water pump. Unfortunately you can't see the spurting coolant below the brass nut in the video
It spurts sideways from the bottom to the top of the video under the water pump flange, so I'm thinking either the gasket has crapped out or the pump flange is cracked.
When I get some of the stuff out of the way I'll be able to get in there better while pressure testing.
Better buy more beer
Old May 30, 2012 | 11:40 PM
EvisceratingAxe's Avatar
EvisceratingAxe
7th Gear
If you can afford it throw a high flow pump on. I've always replaced the pump when a seal fails if I can. Its just a good safety net.
Old May 31, 2012 | 12:07 AM
Calderone's Avatar
Calderone
Edelbrock 8815 or 8825 if you want it polished , it's a very very good pump !
To Waterpump?
