First Timer Advise
Old Jun 1, 2012 | 09:39 PM
96 Vette CE's Avatar
96 Vette CE
Banned Loser
From: They say you learn from your mistakes, I must be a genius
2017 Corvette of the Year
2016 C4 of Year Finalist
Creator of the "Original" whining and crying thread
St. Jude Donor '14-'15-'16-'17
Default First Timer Advise
I'm wanting to take the CE to the track this year. Street stock class, any advise?
Old Jun 2, 2012 | 12:34 AM
yaknow's Avatar
yaknow
make sure your brake fluid and pads are fresh
Old Jun 2, 2012 | 06:54 AM
HlhnEast's Avatar
HlhnEast
Drive line and F/R bearings in good shape. The weakest link will likely be found.
Old Jun 2, 2012 | 08:38 AM
aminnich's Avatar
aminnich
Steve, just make sure everything is good on the car. You can do things like removing spare tire and 'stuff' to reduce the weight, but running stock the effort isn't really worth it. Main thing is to stay safe, have fun, and stay in the groove. You going to a 1/4 mile track?
Old Jun 2, 2012 | 11:24 AM
96 Vette CE
Banned Loser
I just changed out the pads and rotors and flushed the entire system.
Yes Andy 1/4 mile track. The car is completely stock other than a K&N filter and a little bling. I've just had the "itch" lately of wanting to take it to the track and see how i would do. I don't really want to beat the snot out of it, but i think a few passes would be fun.
Thanks guys.
Old Jun 2, 2012 | 11:43 AM
aminnich's Avatar
aminnich
Steve, it is fun. I have at least a couple hundred passes on mine, but all on an 1/8th mile track. Nearest 1/4 mile track is 2 hr drive one way. A day at the track is always a fun day, beating a Mustang is even better.
Old Jun 2, 2012 | 11:50 AM
96 Vette CE
Banned Loser
I hear ya on beating a Mustang. The nearest 1/4 mile track is about an hour and 1/2 away from me, so it will be a little ride. Just hoping i don't break something, or the ride home will take a little longer.
Do you still have both vettes?
Old Jun 2, 2012 | 11:56 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Two important lessons I can pass on:
1) Lightly spin the tires before staging. Drive around the water box. Big smoky burnouts are not for street tires.
1a) When Staging, after you light the first staging light, creep very slowly to light the second staging light. This will set you up for the next step.
2) Watch the light tree and launch on the last yellow. By the time your brain processes the information, and your feet start to move, the light will be green.
OK that's three but why bother counting. Have fun and remember to post your times here.
Old Jun 2, 2012 | 12:23 PM
Frizlefrak's Avatar
Frizlefrak
Sounds like fun!
Old Jun 2, 2012 | 12:34 PM
96 Vette CE
Banned Loser
Thanks Coach. My times may be a little embarassing, but i'll post them up anyway, if you can't laugh at yourself.....
Old Jun 2, 2012 | 01:53 PM
aminnich's Avatar
aminnich
Don't worry about the times. No matter what you do there will always be someone else faster. jrriflecoach gave good advise, not much I can add to that other than try not to spin the tires. Launch as hard as you can without spinning.
Old Jun 2, 2012 | 06:37 PM
93Rubie's Avatar
93Rubie
Post your times, no option NOT too.
Are you running a stick or auto?
Old Jun 2, 2012 | 07:07 PM
96 Vette CE
Banned Loser
Stock LT1 auto with 3:07 gears.
Old Jun 2, 2012 | 10:03 PM
93Rubie's Avatar
93Rubie
Leave on the converter as much as you can without spinning. I like my Kumho's at 26psi HOT. Track conditions/your tires will determine what you can do, adjust pressure accordingly.
You got the good gear set.
To First Timer Advise
