Flippin headlight
Old Jun 5, 2012 | 06:49 PM
ChrisG84's Avatar
ChrisG84
Default Flippin headlight
Well, go ahead and call me an idiot!!!!!
I turned off my headlights and the left headlight didn't go down. I tried turning them on and off a couple of times and it still didn't go down. So...... I decided to just push it a little and............... now it flips up, but doesn't lock in place and the motor goes.... rattle,rattle,rattle,rattle,rattle,rattl e,rattle,rattle,rattle,rattle,rattle,rat tle,rattle!!!!!!!!!!!!
So, am I screwed, need to get a new one or hope there's one at a junk year, or...... does anyone have a magic wand fix they know about,,, a little pixie dust would be great! Wasn't there a recall on these?
Old Jun 5, 2012 | 07:53 PM
VetteMed's Avatar
VetteMed
you either have worn out bushings or stripped gears in the motor.
No recall, you're on your own. New bushings are only a few bucks, and new gears are available too. Not a very difficult job, but a bit time consuming the first time you do it.
Old Jun 5, 2012 | 08:02 PM
ChrisG84's Avatar
ChrisG84
Very cool. Any idea where I can get new bushings and gears?
Old Jun 5, 2012 | 08:10 PM
Dans 85's Avatar
Dans 85
There is no magic fix.
I'd unplug the headlight motor connector (grey plug) until fixed to avoid a possible battery drain.
You don't mention the year of your car. Assuming it is an 84, it is more than likely the white gear is stripped out inside the motor itself. This gear rides the steel worm gear of the motor. There is another black gear but I doubt it will need replacement.
$25 for the gear and few hours of your time will make it good as new.
Dans 85's Avatar
Dans 85
Check the major vette catalog places for the part
Old Jun 5, 2012 | 08:21 PM
VetteMed's Avatar
VetteMed
Ecklers, Corvette Central, Mid America, any of 'em should have acceptable replacement parts. May check with Keen Parts too, they've brought some nice C4 products to market lately.
Old Jun 5, 2012 | 08:23 PM
ChrisG84's Avatar
ChrisG84
Awesome!!! Thanks everyone!
Old Jun 5, 2012 | 11:34 PM
Cliff Harris's Avatar
Cliff Harris
By your sig I assume it's an '84. In that case you need one of these:
I don't remember where I got it. Eckler's or more probably Mid-America.
I keep this one as a spare since I've gone through two on the left side. The right side is still the original. They also make a bronze version which will never strip. I may go that way next time.
To Flippin headlight
