Potential newbie
Old Jun 9, 2012 | 01:51 PM
Curly2001's Avatar
Curly2001
Default Potential newbie
I am trying to make a pretty safe purchase for a C4 Corvette. I have rheumatoid arthritis which will limit some things I can do. Is a 91 a pretty safe bet? I was thinking of a C3 but afraid of the non electronic ignition thinking the newer ones will be less work. Also not sure about all I don't know about the opti system. Does the 91 have that?
Thanks in advance.
Curly
Old Jun 9, 2012 | 01:52 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
91 does not have the opti. That started with the LT1 in 1992.
Old Jun 9, 2012 | 02:03 PM
Sweet 90's Avatar
Sweet 90
Also remember, the C4 is the hardest Vette to get in and out of
Old Jun 9, 2012 | 02:33 PM
Curly2001's Avatar
Curly2001
Thanks, I am looking for something that is pretty reliable with decent miles for its age. I can handle getting in and out with a new knee. Hoping things won't go further south on me. Any other year suggestions would be appreciated. I have a couple of cars here in Arizona in mind.
Thanks again,
Curly
Old Jun 9, 2012 | 06:29 PM
FOURSPEEDVETTE's Avatar
FOURSPEEDVETTE
1991 C4's are great Corvettes, but the C5 will be alot easier for you to get in and out of with arthrits. Not bashing the C5 here, but many older owners buy C5's for this very reason. Plus many C5's can now be picked up cheaply and getting cheaper every month. Good luck with your Corvette whatever year you get. They're fun cars.
Old Jun 9, 2012 | 09:26 PM
mrmtrtrnd's Avatar
mrmtrtrnd
Good luck on your search.
Old Jun 9, 2012 | 09:48 PM
Jon Hekking's Avatar
Jon Hekking
Pass on the C3, very uncomfortable cars to drive and I love the things. C4 will kill your knees climbing out. C5 is a better fit.
Old Jun 9, 2012 | 09:54 PM
Frizlefrak's Avatar
Frizlefrak
C4 is a "fall in, roll out" for those of us who are....let's say....not 25 anymore.
Drive both a C4 and a C5 before you decide.
Old Jun 9, 2012 | 10:21 PM
dlrx's Avatar
dlrx
I just try not to step into/out of a c4. Sit, pivot, and reverse to exit, winging both arms/elbows on the pillars to pull up and get out.
Left knee = 4 surgeries, bad back, arthritis all at 50...I get in/out OK. Stepping in tho is a disaster, just not young/agile/flexible enough any more.
Old Jun 9, 2012 | 10:30 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
What price range are you looking at? If in the 30s then a C6. 20s for C5s and teens for a nice C4. A C4 convertible is easier to get in and out of with the top down. Sounds like you should avoid the stick shift Vettes.
Now - if price is not a factor then a C6 Z06 is the best performance bang for the buck. Just dose up on the NSAIDS before you start clutching and shifting!
Old Jun 9, 2012 | 10:40 PM
Jon Hekking
Don't do that, Non-steroidal anti-inflammatory drugs have several side effects the most dangerous is an increase in BP. That along with the possible frustration of a C4 and your head will explode.
Old Jun 9, 2012 | 11:20 PM
ch@0s's Avatar
ch@0s
Buy a truck
Old Jun 9, 2012 | 11:25 PM
Curly2001's Avatar
Curly2001
Thanks for all the help. I would say my finances for now are in the C4 price range. I am still able to get in and out pretty well. I am not sure what rattles worse, me on the pills or the car. Are the 90-91 cars maintenance friendly? I can do the routine stuff but the heavy lifting is where things start to get rough. I know with more miles front ends start to go and things such as that. Have found some cars with bad A/C and am not sure what things like that cost to repair. Also, how hard is the weather stripping to replace?
Thanks again.
Curly
Old Jun 9, 2012 | 11:30 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Originally Posted by ch@0s
Buy a truck
yep, newer trucks have the LQ4, a LS engine with an iron block.
Old Jun 10, 2012 | 12:20 AM
Frizlefrak's Avatar
Frizlefrak
Thanks again.
Curly
Weather stripping isn't hard, just time consuming to get the old stuff out. Maintenance is reasonably simple on a C4, but repairs will get VERY pricey if you can't do them yourself.
I've said this a ton of times...if you can do your own wrenching, an old C4 (which is all of them) can be kept running forever for a reasonable sum. If you have to farm it out every time it hiccups (and it WILL hiccup), it can and will bankrupt you.
Labor is close to $100 an hour these days. Something to think about.
Old Jun 10, 2012 | 12:59 AM
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
Old Jun 10, 2012 | 01:19 AM
tpfarm's Avatar
tpfarm
I have a 91 convertable and love it. I have a 20 year old artificial hip and I have to get in and out like a girly man. You may be able to pick up a real nice 90 cheaper which is the same car under the skin as the 91.
To Potential newbie
Old Jun 11, 2012 | 12:45 AM
Phat98's Avatar
Phat98
After years off perfecting the egress of a C4, I'm having difficulty getting in and out of the Missus' C5...that seat is definitely lower, and you don't have that door sill to brace yourself getting in either...
Old Jun 11, 2012 | 11:42 PM
Curly2001's Avatar
Curly2001
I am looking for that gem of an early model 90-91 car. So far, I can get in and out pretty well of a C3 that a buddy owns. Thanks again for all the help. Need to find a club in Tucson so I can absorb some knowledge from them before I buy.
Curly
Old Jun 12, 2012 | 03:24 AM
USABaja5's Avatar
USABaja5
Check the Phoenix Craigslist ads. There are always a few 90-91 C4s every week. I feel very old when I get in and out of my son's C4. I would check a few out and make sure you can handle it.
For Arizona owners, you can also check out -- http://www.arizonacorvetteenthusiasts.net
