Wheel/tire diameter and speedometer reading
Old May 24, 2002 | 11:33 AM
Scoob's Avatar
Scoob
Default Wheel/tire diameter and speedometer reading
If you increase your wheel/tire diameter, which way does that affect the speedometer?
For example, assume a 1.5% diameter increase. At a true speed of 65 mph what does my speedometer show? 66mph or 64mph?
Old May 24, 2002 | 06:05 PM
carter200's Avatar
carter200
Default Re: Wheel/tire diameter and speedometer reading (Scoob)
bigger tire = lower than real speedo reading
smaller tire= higher than real speedo reading
Old May 24, 2002 | 06:15 PM
Shark ssn591's Avatar
Shark ssn591
Default Re: Wheel/tire diameter and speedometer reading (carter200)
yup yup yup.. I have a program that will give actual speed.. for a given RPM, tire size gear ratio (let's you input the tranny, which gear, rear end and tire size) then you put in the rpm it tells MPH, sortta cool. any one who wants it email me
To Wheel/tire diameter and speedometer reading
