86 A/C Question???
Old Jun 13, 2012 | 10:26 PM
rrt898's Avatar
rrt898
Default 86 A/C Question???
I want to know do you have to change the compressor if you convert from R12 to R134?? What parts do I need for the conversion? I am about to change my radiator and thought about changing the condenser also. That would be the time to convert the A/C.
Thanks for the help.....
Old Jun 13, 2012 | 11:05 PM
cuengineer's Avatar
cuengineer
You should not have to change the compressor if it is working good and not leaking. Typical recommendation is to change the dryer/filter and evacuate the system before you put in the R134 and oil. You will want to check capacities and add gas based on gage readings. You might also want to carefully look at all hoses and replace any suspect ones at this time. Good luck!
Old Jun 14, 2012 | 03:36 AM
Cliff Harris's Avatar
Cliff Harris
There are kits to do the conversion that have all the parts you need.
Personally, I'm sticking with R12.
Old Jun 14, 2012 | 07:42 AM
Muffin's Avatar
Muffin
Considering the price of 134A now R12 might be the better investment.
To 86 A/C Question???
