sensor blocking egr removal
Old Jun 19, 2012 | 03:26 PM
grsee's Avatar
grsee
Default sensor blocking egr removal
Hi. Does anyone know what type of sensor is just in back of the egr valve on a 95 lt1 (just to the right of it looking from the drivers side)and if so which size wrench or socket would fit it? I went to replace the egr and this (well it looks like a sensor anyway) is blocking it so I have to remove it also. Problem is that the base of this thing is way down below the egr and very hard to get to. Any help is appeciated.
Old Jun 19, 2012 | 07:07 PM
Red Dwarf's Avatar
Red Dwarf
IIRC, the oil pressure switch is located some where back there. It's been a while so just a guess.
Some one will be along shortly to help you out.
This shud give you a bump.
