Larger wheels????
Old Jun 24, 2012 | 09:18 AM
1960lespaul's Avatar
1960lespaul
Default Larger wheels????
I have 17 inch sawblades on my 94 vert but I hate the gap between tire and fenders. Anyone running larger wheels without any suspension mods? I would love to see some pics to see if I would like the look.
Old Jun 24, 2012 | 09:27 AM
CREWZIN's Avatar
CREWZIN
With larger wheels comes thinner sidwall tires (use the Plus + setup) so your odometer and speedometer will stay correct. You won't loose the gap between tire and fender.
Old Jun 24, 2012 | 10:58 AM
Tommy T-Bone's Avatar
Tommy T-Bone
St. Jude Donor '06-'07-'10-'11-'12-'13-'14
Pics of wheel gap?
Old Jun 24, 2012 | 12:11 PM
TA's Avatar
TA
You need to lower the car a bit.
Old Jun 24, 2012 | 05:09 PM
1960lespaul
Here is the best I have now. Not opposed to lowering the car but didn't want to mess with the ride. But looks come before ride so if I have to lower what are the easiest/cheapest options since I plan on buying wheels anyway. I would still like tosee some pics of larger wheels on a C4
Old Jun 24, 2012 | 05:18 PM
COPO's Avatar
COPO
Largest I know of that still fits the car and don't look like a donk.
mrmtrtrnd's Avatar
mrmtrtrnd
You can go with larger wheels but once the car is lowered 17" look great and won't add extra weight that is often found in larger wheel tire combos.
Now if you want a bad a$$ look like COPO you can't get any better than his.
Old Jun 24, 2012 | 07:10 PM
1960lespaul
What size (19 and 20?) and has your car been lowered as well? Are those custom wheels or from another Vette? Did you have to do anything to get them to fit?
Old Jun 24, 2012 | 10:07 PM
COPO's Avatar
COPO
They are 19's it is lowered and the wheels are custom. Yes I had to change a few things.
Old Jun 24, 2012 | 10:18 PM
Smokedavette's Avatar
Smokedavette
I have 2006 wheels on my 1987 they are 18" in front and have 25" tall and 9.5" wide tires, the rears are 19" with 26" tall and 11" wide tires. I needed 1" adaptor spacers to make them fit. In this picture I do not have the spacers on the front yet so they are inset too much but you can drive the car with them and it does not rub anywhere at all.
Old Jun 25, 2012 | 08:53 AM
1960lespaul
Originally Posted by Smokedavette
I have 2006 wheels on my 1987 they are 19" in back and 26" tall and 9.5" wide tires, the fronts are 18" with 26" tall and 11" wide tires. I needed 1" adaptor spacers to make them fit.
I wonder if I will need the spacer on a 94. If I stay with 17s what is and nice economical way of doing it? New lowering springs or a lower kit with stock springs?
Old Jun 25, 2012 | 10:06 AM
5abivt's Avatar
5abivt
there a thread 2 or 3 pages back do a search for it it has like 70 pages of wheels on c4s. nevertheless an excuse to post a pic
Old Jun 25, 2012 | 10:59 AM
FWC's Avatar
FWC
St. Jude Donor '13, '15-'16,'18 thru '25
Mike, that pic belongs in a calendar sweet car.
Old Jun 25, 2012 | 11:56 AM
johnnymo63's Avatar
johnnymo63
2021 C4 of the Year - Modified Finalist
C4 of Year Finalist (appearance mods) 2019
Changing wheels and tires won't get rid of the gap much.
You don't need wheel adapters if the "offset" is same as stock, (around 54-56 mm).
You'll need to lower it some.
I lowered mine for free. I trimmed the pads on the front spring 50% and drilled new holes for the cotter pins in the rear spring bolts as low as possible. (I should have got the "lowering bolts" for the back. A little lower would look perfect.)
Stock with 17s.
Stock height with 18s.
Lowered with 18s front, 19s rear.
Old Jun 25, 2012 | 07:29 PM
bangbgC6's Avatar
bangbgC6
Here is the best I have now. Not opposed to lowering the car but didn't want to mess with the ride. But looks come before ride so if I have to lower what are the easiest/cheapest options since I plan on buying wheels anyway. I would still like to see some pics of larger wheels on a C4
Old Jun 25, 2012 | 08:04 PM
LT5corsa's Avatar
LT5corsa
1994 Admiral Blue ZZZZZR1
Northeast Events Coordinator
I recently installed 18 front / 19 rear fikse's with new Michelin pilot sports. (345 30 19)
David
Old Jun 27, 2012 | 01:53 AM
Phat98's Avatar
Phat98
18x9 front, 19x10 rear
To Larger wheels????
Old Jun 27, 2012 | 12:04 PM
Bimmervet's Avatar
Bimmervet
St. Jude Donor '12-'13-'14-'15-'16
18 x 9 all around with 275 x 35 Lowered in back only with VBP lowering bolts
Old Jun 27, 2012 | 01:06 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
David
Damm that's a beautiful car!
Old Jun 27, 2012 | 10:43 PM
1960lespaul
Everybody's car looks great. I hope mine turns out just as good. Looks like I will be lowering the car to achieve the look I want.
