light switch knob
Old Jun 25, 2012 | 11:24 PM
tntwolt's Avatar
tntwolt
Default light switch ****
how does a C4 light switch **** come off?
Old Jun 25, 2012 | 11:36 PM
Dans 85's Avatar
Dans 85
Pull headlight **** fully out, then use a hook tool to pry release tab on backside of the ****. May have to turn it a little to get it in position where the tang is.
Old Jun 26, 2012 | 12:42 AM
Cliff Harris's Avatar
Cliff Harris
Two ways:
Push on the clip on the back of the **** (my **** is epoxied on the shaft because it used to fall off -- that's the yellow stuff):
Second way: Take off the dash pad. Press inward on the button with the spring that looks like the head of a nail on the side of the headlight switch (the shaft comes out when you do this -- this method goes WAY back to the 1950s at least):
Old Jun 26, 2012 | 12:55 AM
Frizlefrak's Avatar
Frizlefrak
Cliff nailed it. Sometimes the clips break, and previous owners glue them onto the shaft. Then the pad comes off....which is fortunately, a 10 minute job on an early C4.
To light switch knob
