determining VATS
Old Jun 27, 2012 | 09:00 AM
andrewLT1's Avatar
andrewLT1
7th Gear
Default determining VATS
good morning , i have a 1992 coupe with no ignition key, how can i determine which of the 15 options is the right VATS code key for my car without going through every key from the dealership? Hope someone can help, extremely frustrated.
Old Jun 27, 2012 | 11:19 AM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
I just have to ask: How did you end up with a car without a key?
Old Jun 27, 2012 | 12:11 PM
Smokedavette's Avatar
Smokedavette
It could have been a repo, impound, inherited or michanics lean to mention a few reasons for no key.
Old Jun 27, 2012 | 01:12 PM
TA's Avatar
TA
The first thing I'd try is to take proof of ownership to a GM dealer and see if the the key info is on file. I can tell you it's definitely hit or miss with records this old, but maybe you'll get lucky.
If that doesn't work you can try to see if the dealer or a local locksmith has a VATS Interrogator.
If you strike out there you can do what I did when I lost my one and only set of keys years back. I first bought and installed a new ignition lock cylinder. The new cylinder comes with a generic key with no VATS pellet, but it will at least allow you to turn the ignition. I then followed the VATS wires from the ignition to a connector. I unplugged the connector and then proceeded to duplicate all 15 possible VATS resistances until I got the car to fire. I then took the key I got with the new cylinder and the resistance I'd found to a GM dealer and had them cut multiple spare keys. The whole project took me a few days, but I got the car running.
Old Jun 27, 2012 | 06:41 PM
Dans 85's Avatar
Dans 85
TA's advice is spot on.
Worst case scenario is it will take 15 attempts.
How many was it for you TA?
Old Jun 27, 2012 | 07:46 PM
WVZR-1's Avatar
WVZR-1
Max attempts 14 - there's no #1 except 1st year!
The wisest move get codes from dealer - generally speaking the VATS ID on something older than '93MY the code will likely NOT be included with the key code request. Maybe? Yes !! You WILL NEED Current title (your name) or current registration and picture ID that is a match!
Get a VATS work key cut to the mechanical code of the key. If it rotates you're most of the way there. There's no chip but it's inexpensive. Then if the VATS was included with key code give it a go!
VATS work key: 26007687
Good - luck !!!!!
Old Jun 27, 2012 | 08:51 PM
TA's Avatar
TA
If I recall correctly, it actually took me about 24 attempts over two days.
The first time through the list I messed up the resistances.
It was very frustrating, but a nice sense of accomplishment when it roared to life.
Old Jun 27, 2012 | 11:23 PM
trulytex's Avatar
trulytex
Check to see how much for a new lock cylinder with new keys. I think that the dealership can reprogram the car's computer to the new VATS code.
I think that you can also send your computer module to someone and have the VATS program removed.
Old Jun 28, 2012 | 04:34 AM
toptechx6's Avatar
toptechx6
I have a VATS interrogator if you happen to be located in south Fl.
Old Jun 30, 2012 | 01:08 PM
andrewLT1's Avatar
andrewLT1
7th Gear
try ex-wife being spiteful on her way out the door
Old Jun 30, 2012 | 01:31 PM
Sworn's Avatar
Sworn
St. Jude Donor '12
Ouch!
Old Jun 30, 2012 | 05:07 PM
MK 82's Avatar
MK 82
Them bitches will cut you then laugh while you are bleeding!
Old Jun 30, 2012 | 07:10 PM
WVZR-1's Avatar
WVZR-1
Where are you actually located?
Your original post was WED so I'd certainly think if you have all of the required documents you've been to a dealer and have what information was available. Did the VATS information come with the key request to the dealer? Might be useful information for others with older 'MY GM vehicles.
Old Jul 3, 2012 | 08:36 AM
andrewLT1's Avatar
andrewLT1
7th Gear
I am in Toronto, Canada. I have talked to the dealer they want to tow my car in and see if they can get the VATS info off the computer. Basically they want to screw me out of @ $1000 just to start my car, im in no rush its not my only car.
Old Jul 3, 2012 | 08:45 AM
TA's Avatar
TA
So GM didn't have any key/vats info on file for your VIN?
Old Jul 3, 2012 | 09:36 AM
andrewLT1's Avatar
andrewLT1
7th Gear
They said they only have the info for 15 yrs, but they didnt sound to positive, part of the reason i joined this forum, to talk to people who are smarter and more helpful.
Old Jul 3, 2012 | 10:19 AM
WVZR-1's Avatar
WVZR-1
They said they only have the info for 15 yrs, but they didn't sound to positive, part of the reason i joined this forum, to talk to people who are smarter and more helpful.
Did you actually hand them registration and a picture ID for ownership confirmation or did you just ask? I doubt a Canadian inquiry would be that dramatically different than a USA request! I believe at least the mechanical component would be available with a VIN request here in the US.
If you've got the required documents go to the same or different GM dealer with it in hand. Any GM dealer can help you, they're not obligated but are generally responsive. You've lost keys and you'd like them to do a KEY REQUEST through their GM Direct inquiry system. The parts department is generally where this would be initiated.
You remain very vague about what you've actually attempted.
There's knowledge here but it requires accurate information!
To determining VATS
Old Jul 3, 2012 | 05:29 PM
andrewLT1's Avatar
andrewLT1
7th Gear
slow down my american friend, dont be so quick to insult me, i have asked the dealership what my options are on three occasions, and have e-mailed Bowling Green Assembly plant as well. I simply posted a straight forward question wondering if anyone had been in the same situation, any advice i have received i appreciate , any insults.....not so much, and unlike most Canadians im one mean, tough, son of a bitch.
Old Jul 3, 2012 | 05:31 PM
Vette Daddy's Avatar
Vette Daddy
Old Jul 3, 2012 | 06:39 PM
WVZR-1's Avatar
WVZR-1
You've made it substantially easier to understand your situation!
