First Corvette , any issues
Old Jul 3, 2012 | 06:44 PM
Lee36's Avatar
Lee36
8th Gear
Default First Corvette , any issues
Wanted to say hi my name is Lee. I recently purchased my first vette a 1988 l98 auto with 105k (needed a toy while im restoring my 69 camaro ) . Have a question my car will barely spin tires from a dead stop( barely one revolution ) is this normal for these cars with their gearing or do i have a problem. I just changed plugs wires cap rotor and coil. i did have a miss before and thought that was maybe why but no. I eventually want to use this vehicle for drag racing after my camaro is done. As far as i can tell the car is completely stock except maybe the mufflers, i havent got underneath vehicle yet to look . Was there any major issues with theses cars that i should look for ? Also ive notice at times when you start it it dies right away or will cut in and out for a couple of seconds before it staightens out of it still doing since tune up . I did replace both relays for Maf as i had a code 36. Thanks in advance for any thoughts on this.
Old Jul 3, 2012 | 09:43 PM
Buckeye99's Avatar
Buckeye99
I used to own an '87 automatic with the 2.59 rear end and can tell you it had absolutely NO problem smoking the tires from a dead stop. My car was stock with the exception of the Borla mufflers.
From my limited experience with these cars (~two years), the L98s tend to have issues with the intake gasket eventually giving out and leaking coolant. However, I am unaware of any "major" issues with these cars that would cause a loss of torque. I'd check all the normal stuff: fuel pressure, throttle body/IAC, spark gap/timing, etc. You may also want to change your fuel filter if you haven't already.
Maybe some of the more senior members have some ideas...
Old Jul 3, 2012 | 09:56 PM
ghlkal's Avatar
ghlkal
2018 C4 of Year Finalist
Lee, as buckeye said, even if you have 2.59 gears you should be able to smoke the tires some. The L98 has a lot of torque.
Maybe you have really sticky tires
Oh, and welcome to the forum and Corvette ownership!
Old Jul 4, 2012 | 12:17 AM
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
Welcome to the forum!
Old Jul 4, 2012 | 02:41 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
There are a few things to boos power:
-remove the "frisbee" disc from the front of the WP pulley
-bump base timing to around 8deg BTDC
-cut back electrodes on stock spark plugs
-install a 160 deg T-stat & fan switch
-replace the front Y with a hi-flow unit (no pre-cats) & a hi-flow cat
-cut the air filter lid and install a K&N filter
-install an AFPR and boost fuel pressure (vac hose off) to say 48psi
-remove the spare & jack and run with 1/4-3/4 tank of fuel
-bump the TPS sensor idle reading to around .75 VDC or .65 VDC if at base idle of 450rpm
With these and a few other simple mods I had my '88 up to nearly 300chp still with stock cam, headers and heads.
Welcome to the "club"; enjoy your '88 Vette...
To First Corvette , any issues
