Door panel problem
Old Jul 6, 2012 | 11:08 PM
JDooley's Avatar
JDooley
3rd Gear
Default Door panel problem
OK. I have done the search thing and have read all the post but I am still having a problem with my 93 passenger side door panel. I cannot seem to see what the door panel hangs onto at the top of the door. I have done the L bracket but the panel still wants to slip off. The gusset type bracing is not broken so that is not the problem. Can anyone tell me what holds the panel onto the door and does anyone have any other ideas what the problem might be?
Old Jul 7, 2012 | 12:37 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If you place three "L" brackets along the door top and the panel lib slides down over each of them then the panel cannot slip off, unless the panel lip is bending.
If the panel lip is bending, it can be reinforced with some thin Al panel & JB Quick.
Old Jul 7, 2012 | 08:47 AM
mfi's Avatar
mfi
I went through this and tried a lot of things..finaly shot 2 screws through the top of the panel into the door..kind of hid them under the window wipe..it was a last resort but worked well..these panels warp..try to find the post where he used wire ties to bend and hold the panel in shape..I tried it but it didn't work...
Old Jul 7, 2012 | 10:20 AM
vittal's Avatar
vittal
I had the same problem with mine when I got the Vette.
There's how I fixed and after a year it's still holding very well.
http://forums.corvetteforum.com/1578051927-post55.html
Best of luck to you.
Bye
Old Jul 7, 2012 | 09:16 PM
Old Ben's Avatar
Old Ben
2017 C6 of Year Finalist
I had to do the same. The panels were warped and none of the fixes worked. They need to be replaced but for $900 a pair, I can live with the screws for now.
Old Jul 7, 2012 | 11:10 PM
JDooley's Avatar
JDooley
3rd Gear
Thanks to all of you who replied and made suggestions. I finally fixed the problem today - after about 6 hours of trial and error. I used the L brackets and also used a couple of screws (hidden and inconspicuous). Seems to be holding up well for now. Thanks again.
To Door panel problem
