running hot
Old Jul 8, 2012 | 07:35 AM
tlasalla's Avatar
tlasalla
2nd Gear
Default running hot
just bought a 92 and seems to run hot around town goes up to 230 then goes back down when fan kicks in on highwayb runs cool anybody else ever had had this
Old Jul 8, 2012 | 08:55 AM
Leftoverture's Avatar
Leftoverture
You probably need to pull your radiator and clean the crap out from between it and the condenser. Very common problem with C4's as they are bottom feeders...basically they suck cool air in from underneath so they're like giant vacuums sucking up road crap. Very easy fix, though.
Old Jul 8, 2012 | 10:59 AM
Jon Hekking's Avatar
Jon Hekking
C4 owners should get a kick back on their taxes as they help keep the roads clean.
Old Jul 8, 2012 | 12:45 PM
chevyc4man's Avatar
chevyc4man
Mine has always done this, from what I understand this,is fairly normal in c4's?
Old Jul 8, 2012 | 01:57 PM
Frizlefrak's Avatar
Frizlefrak
How many street sweeper drivers have been layed off since the C4 hit the roads 29 years ago?
They do, but keeping the front of the radiator clean is imperative.
Old Jul 8, 2012 | 03:25 PM
IAFF alumni's Avatar
IAFF alumni
200 is 'normal' for a 92 LT1.
At 228, my fans kick on and bring the temp down to something less.
It concerned me at first, but I learned here that these engines tend to run hot due to their emissions requirements.
Keep the radiator area clean and enjoy her.
Old Jul 8, 2012 | 03:37 PM
pianoguy's Avatar
pianoguy
Also check to make sure there isn't any air in the cooling system. Hold a rag under the bleeder screw and crack it open when the engine is warm, then close it when nothing but fluid comes out.
To running hot
