1-4 skip shift
Old May 27, 2002 | 04:59 PM
94 M-6's Avatar
94 M-6
Default 1-4 skip shift
I am still looking for a vette, and I am wondering what years had the 1-4 SS, what it is really all about, etc
Thanks...
Old May 27, 2002 | 05:04 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: 1-4 skip shift (SVT)
I believe it started in 1989 up to the present.
You can disconnect the solenoid, or always keep the throttle past 25% to defeat it.
Old May 27, 2002 | 05:19 PM
vader86's Avatar
vader86
Default Re: 1-4 skip shift (Mr Mojo)
all 6 speeds have it to my knowledge
Old May 27, 2002 | 09:28 PM
96LT4's Avatar
96LT4
Former Moderator
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
CI3 Car Show Winner
Like Mojo said, you can just disconnect the thing, or buy the bypass plug. :seeya
Old May 27, 2002 | 09:36 PM
INaband's Avatar
INaband
CI 7-8 Veteran
Default Re: 1-4 skip shift (96LT4)
Yeah, and I dont know anyone that leaves their's connected. :smash:
Old May 27, 2002 | 09:44 PM
Sandy S's Avatar
Sandy S
I understand it was a way to get good/better EPA gas milage numbers with the 6-speed. If you are accelerating slowly it (guides?) forces you to shift from 1 to 4 rather than 1 to 2. I originally thought my transmission was broken. If you rev just a bit higher before shifting it turns off. I have gotten used to mine and have not bothered to disable it.
Old May 27, 2002 | 09:46 PM
Rich_01659's Avatar
Rich_01659
Default Re: 1-4 skip shift (INaband)
mine is still connected. it really bugs for about the first month you drive with it. if you don't dissconnect it you will get so used to it you will forget that it is even there. DON'T MISUNDERSTAND i do not shift 1-4, i wait for 2nd gear to open up. two signals you learn to look for.... 1) the 1-4 light will be on so DON'T shift, and 2) if you miss the warning light you will notice a slight resistance (before you grind). It really take no effort to work around the 1-4 shift. All that said .... if you have the wherewithall go ahead and dissconnect the thing :)
Old May 27, 2002 | 10:00 PM
96LT4's Avatar
96LT4
Former Moderator
Cruise-In V Veteran
CI3 Car Show Winner
I have it bypassed on both of my cars. :yesnod: Always seems to come on in a corner. :mad
To 1-4 skip shift
