Driver Side Window
Old Jul 14, 2012 | 07:20 PM
95VetteMan1's Avatar
95VetteMan1
Default Driver Side Window
My driver side window will not raise or lower..but the passenger window will lower and raise...any suggestions?
Old Jul 14, 2012 | 07:27 PM
Railroadman's Avatar
Railroadman
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
Welcome to the club - my symptoms exactly!
Using the procedure in the FSM, I determined the switch itself was OK, the problem is in the motor.
Ordered a motor from CC on the 2nd, guy said it would ship the 6th. Called on the 13th, it's not in stock, said they'd call me back with an estimate of when it would be available.
After a couple hours waiting for a call-back, I called Vette2Vette, ordered a regulator & motor, it will ship Monday. Called the other place and cancelled the order!
Here's a link to a good write-up on changing the thing out:
http://forums.corvetteforum.com/c4-t...with-pics.html
Good luck and let us know how it goes.
Old Jul 14, 2012 | 07:52 PM
95VetteMan1
Thanks how do you determine if its the switch..or motor?
Old Jul 14, 2012 | 08:09 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Troubleshoot it. You can use a voltmeter.
That happened to me and one of the motor brushes went bad, An alternator repair shop fixed it for $10.
Old Jul 14, 2012 | 08:20 PM
pjgiantsfan's Avatar
pjgiantsfan
My 1993 passenger side window stopped working. Removed door panel and disconnected motor. Plugged back in and it worked fine. Cleaned contacts just in case. Maybe it was just a little loose.
Old Jul 14, 2012 | 08:54 PM
Railroadman
Sometimes that's all it takes. Don't overlook the simple things.
Old Jul 14, 2012 | 09:43 PM
gerardvg's Avatar
gerardvg
That is what i found on my 85 vette with the later model window regulators, if the plug is not on straight and was pulled on an angle by the wires under tension. Or the repeated slamming of the door.
Not a problem since so check if the window motor works, when you close the door while holding the switch in the up or down position.
Old Jul 15, 2012 | 11:59 PM
C422's Avatar
C422
Default Window repair
I've repaired my switches and my motors myself. The switch's contacts get dirty, and sometimes all you have to do is get that switch apart (which isn't super easy, but doable) and clean them up nice.
The brushes in my motors were dirty, and all you have to do there is take the rivets out, pull the motors, take them apart and clean the brushes up. Pop them back in and you're good to go. A servo motor going bad is pretty unlikely. Much more likely that something is dirty in there. Anyone buying a $300 motor without wrenching on it a bit is, in my opinion, crazy.
To Driver Side Window
