Power lock switch replacement?
Old Jul 17, 2012 | 01:30 PM
Jayhawk62's Avatar
Jayhawk62
Default Power lock switch replacement?
Hi, Must I remove the entire (passenger side) door panel to replace the switch on the power lock?
Old Jul 17, 2012 | 02:41 PM
dukeallen's Avatar
dukeallen
I'm pretty sure you do although it's been two years since I had mine off and I forget. But it will certainly make things easier to get to!
Old Jul 17, 2012 | 04:15 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Yes. Once you get the door card off, there are two small screws that hold the switch in place on the panel.
http://www.ecklerscorvette.com/corve...1984-1989.html
http://www.ecklerscorvette.com/corve...roduct_Related
Old Jul 17, 2012 | 04:25 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
that's not an 84-89 door lock switch
Old Jul 17, 2012 | 04:39 PM
Cruisinfanatic
just remove the black panel that the switch is in, not the whole door panel
Old Jul 18, 2012 | 12:29 AM
Cliff Harris's Avatar
Cliff Harris
It looks like the ones on MY '86 Corvette. Same switch as the power windows.
Old Jul 18, 2012 | 04:26 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
My '88 is the same.
Old Jul 18, 2012 | 10:07 AM
Jayhawk62's Avatar
Jayhawk62
Corvette Central listed my electric window switches as also being for the power door locks......My hope is that the switch IS the problem and not the actuator on the passenger side.
Old Jul 18, 2012 | 10:18 AM
uptown193's Avatar
uptown193
I have switched both out in my 87 and I can confirm that the window switches and the power door lock switches are one of the same. Buy at Ecklers.
My advice to you is take one of the other switches and move it to the passenger side and if it works then you know your problem is the switch and not the actuator. Good Luck....
Old Jul 18, 2012 | 11:44 AM
Jayhawk62's Avatar
Jayhawk62
Corvette Central was cheaper I got three--installed the window switches and those are working well
I believe an actuator is $90.00...yikes. Have any of you bought just the lower door carpeting; not the entire door panel?
How did you get the carpeting off the panel? My problem is the top of the carpeting has "retreated" and shows glue and backing--ugly.
Old Jul 18, 2012 | 01:12 PM
Cruisinfanatic
forgot the 84-85 is different
Old Jul 20, 2012 | 01:42 PM
uptown193's Avatar
uptown193
Kool deal. I bought the lower carpet for my door panels before and installed myself. I first removed any and all staples from the back side. Then I pulled the carpet off which was pretty hard. I used a adhesive remover from Home Depot as well as a razor scraper. The job is time consuming, so Just buy a 6 pack of your favorite beer and get to work.
Your can always look at my treads I started from my profile to see pictures. Good luck.
To Power lock switch replacement?
