Banging on the dash?
Old Jul 17, 2012 | 07:45 PM
JFC's Avatar
JFC
Default Banging on the dash?
Hi,I have an '85 Coupe and the illumination on the digital display went out. Some have said that by banging their fist on the dash their lights came back on. Does this really work? I imagine if there was a loose or bad connection it might be jarred back into place by a hit on the dash. Just wondering if anyone has had success with this. Let me know. Thanks, Jay
Old Jul 17, 2012 | 07:56 PM
dukeallen's Avatar
dukeallen
It works, if you bang hard enough to make the screws come out so you can take it out and clean it, replace the bulbs and check the soldering.
Old Jul 17, 2012 | 09:15 PM
Calderone's Avatar
Calderone
i did it a couple of times , lol , and works fine since then , maybe 3 years ago
Old Jul 17, 2012 | 09:51 PM
Railroadman's Avatar
Railroadman
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
Reading the title, I clicked on this thread with much anticipation - only to realize I've been spending too much time in the "Off Topic" section....
Old Jul 17, 2012 | 11:03 PM
boutyme's Avatar
boutyme
http://temp.corvetteforum.net/c4/vader86/
Some good advice here
Old Jul 17, 2012 | 11:24 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Generally, if you bang your hand/fist/hard object on the dash pad, all you will manage to do is crack the dash pad. If you tap gently on the face of the display, sometimes you will be able to get it to light up. Hit it to hard and you will crack the LCD and destroy the dispay.
Old Jul 18, 2012 | 12:01 AM
Cliff Harris's Avatar
Cliff Harris
I have heard of people banging on the dash pad. It's only styrofoam and you can break it.
I have also heard of a guy who rapped on this cluster and broke the LCD. Be careful.
Old Jul 18, 2012 | 02:28 AM
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
It worked on my 84. After a couple of times I never had an issue again.
Old Jul 18, 2012 | 06:04 AM
mazdaverx7's Avatar
mazdaverx7
i would tap the cluster itself to get the cluster to brighten back up, but would not strike it hard for fear of damaging the lcd panel, lol. so in short, yes it works sometimes, lol.
Old Jul 18, 2012 | 10:26 AM
uptown193's Avatar
uptown193
I have flicked the cluster with my middle finger before and a blub that was dim/out turned back on but I would not be banging on my dash board like a mad man. lol...
Old Jul 18, 2012 | 11:13 AM
FOURSPEEDVETTE's Avatar
FOURSPEEDVETTE
I had a bad lifter once. I used a sledge hammer on the engine and dumped paint thinner into the oil and fuel tank. I read somewhere this would fix it. IT DID! It created lots of other major problems and I forgot about the bad lifter. (don't trust everything you read)
Old Jul 18, 2012 | 11:32 AM
dukeallen's Avatar
dukeallen
Old Jul 20, 2012 | 04:48 PM
uptown193's Avatar
uptown193
Hey it worked for Fonzie (Happy Days) when he would bang on the jukebox it would turn on, so why not a vette dash cluster.
To Banging on the dash?
