upgrading suspension
Old Jul 28, 2012 | 07:58 PM
tc63corvette's Avatar
tc63corvette
Navigator
Default upgrading suspension
I plan on ordering larger anti sway bars front and back, where is the line drawn for too large for street driving, also what is a good brand to look into for anti sway bars and tie rods, $ isnt tight but its not unlimited either, i would like to get the sway bars and tie rods for $600 or less, can it be done using decent parts?
Old Jul 29, 2012 | 09:53 AM
ND2GOFASTER's Avatar
ND2GOFASTER
I just put in a 32mm front sway bar from VB&P and I absolutely love it!!! It was around $180. I'm still planning on putting their 26mm in the rear. Right now I get a little off throttle over steer but I know it's there so I just drive accordingly. I think it's still ok for the street....it is a vette. I expect a little stiffer ride in a vette. I ran my car around the track for one event and I think it handles pretty sweet it made a HUGE difference!!! If you call them and talk with the tech (I think his name is Steve) he's real nice and can help you with some ideas!! Good luck and enjoy!!!!!!!
Old Jul 29, 2012 | 01:20 PM
mcm95403's Avatar
mcm95403
I had the VB&P 32mm front bar on my 84 and was VERY happy with it as well. I'm going to get one and a matching 26mm rear for my 91. Just make sure you use good grease on the bushings, and you'll be good to go.
Of course, after that you'll realize that you need to replace all the rear suspension bushings. They seem to really take a beating unlike the front control arm bushings. My advice there is DON'T use Energy Suspension - go with Prothane. The Energy products seem to have developed "quality creep" and don't fit well at all.
Old Jul 30, 2012 | 08:29 PM
l98tpi's Avatar
l98tpi
Max G’s
The first suspension mod I did on my Vette, before I even started to autox, was the 32mm front and 26mm rear anti-roll bars from VBandP. Nice mod for even the street. It makes the car feel tighter and decreases roll if you have the FE1 suspension. If you have a Z51 or Z07 suspension, you may not want those larger bars for the street.
Old Jul 30, 2012 | 09:00 PM
LT5corsa's Avatar
LT5corsa
1994 Admiral Blue ZZZZZR1
Northeast Events Coordinator
Just ordered one myself for my DRM coil over suspension
Can't wait to install it!!
Cheers
David
Old Jul 30, 2012 | 10:06 PM
93Rubie's Avatar
93Rubie
In addition to the bigger bars, you may want to consider a more aggressive alignment. The one I put on my C4 without changing any suspension component made the car very neutral and it handles quite nicely. I auto-x so I KNOW what the car does at the limit. I have the stock bars and all.
Old Jul 31, 2012 | 12:12 AM
Daniel_Mc's Avatar
Daniel_Mc
Cheers
David
About time!!!
Old Jul 31, 2012 | 12:20 PM
LT5corsa's Avatar
LT5corsa
Originally Posted by Daniel_Mc
About time!!!
Kiss my tushy you bum!!!!!
David
Old Jul 31, 2012 | 05:18 PM
slickfx3's Avatar
slickfx3
go big or go ford
To upgrading suspension
