Fuel Tank Pressure
Old May 29, 2002 | 10:18 PM
MagRed_04's Avatar
MagRed_04
Default Fuel Tank Pressure
Is it normal for their to be excessive pressure in the gas tank? I went thru the whole test procedure in the tech manual and every thing showed ok (all valves, canister, and solenoid). I have to unscrew the cap slowly, and hear a wooosh sound for about 15 seconds or so (can hear the tank flex sometimes). Seems worse as the fuel leverl gets lower. Is this normal? or am I a paranoid individual?
:confused:
Old May 29, 2002 | 10:26 PM
GRX's Avatar
GRX
Default Re: Fuel Tank Pressure (Vette_Crazy)
pressure from fuel evaporating?
[Modified by GRX, 2:26 PM 6/2/2002]
Old May 30, 2002 | 01:29 AM
Ezgoin721's Avatar
Ezgoin721
Mine does the same thing, and it is pressure, not vacuum. Not sure if it's normal or not.
Old May 30, 2002 | 01:43 AM
morphious's Avatar
morphious
Default Re: Fuel Tank Pressure (Ezgoin721)
Same here, especially if my tank is almost empty and it is hot outside. I don't worry because this has happened to me on other cars that I have owned. :cheers:
Old May 30, 2002 | 02:24 AM
Mystic '95's Avatar
Mystic '95
Cruise-In II Veteran
Default Re: Fuel Tank Pressure (morphious)
Must be normal then.. Mine does it too!
BTW.. Never unscrew the cap if you have a puddle of water around the cap, it'll suck it right in... :crazy:
Old May 30, 2002 | 10:37 AM
rodj's Avatar
rodj
Can you blow through the line to the tank from the canister ?
I found some of the steel sectionsunder the car were full of rust and since replacing them I don't get such a pressure build up as I used to.
Some pressure will build up as the tank empties because there is more space for the hot fuel being returned from the engine to vaporize and less cold fuel in the tank to cool it down.
Old May 30, 2002 | 11:39 AM
MARKRUBYRED's Avatar
MARKRUBYRED
:confused:
Perfectly normal :yesnod: and make sure you keep opening the cap slowly to vent or you will end up with a face of fuel :eek: Further, if the cap does not hold pressure it will cause your check engine light to go off.
Mark :seeya
Old May 30, 2002 | 06:10 PM
Justin1984's Avatar
Justin1984
Default Re: Fuel Tank Pressure (MARKRUBYRED)
This is normal. In fact, don't some gas caps have a caution written on them regarding possible tank pressure?
Old May 30, 2002 | 07:02 PM
MagRed_04's Avatar
MagRed_04
Default Re: Fuel Tank Pressure (Justin1984)
I just thought that it seemed abnormal.... I have never had a car do that before. But, I guess I am not the only one.
Old May 31, 2002 | 07:44 PM
rocketfinger's Avatar
rocketfinger
Default Re: Fuel Tank Pressure (GRX)
I may be wrong but I think its vacuum not pressure.
I actually went to the trouble of disassembling the cap and cutting down the spring on the vacuum relief (don't tell the EPA) because I thought I may be 'hanging' fuel in the tank. Next trip to the pump, woosh! It's definitely not vacuum. Pressure I can live with or I'd be cutting that spring too.
Old May 31, 2002 | 08:29 PM
MagRed_04's Avatar
MagRed_04
Default Re: Fuel Tank Pressure (rocketfinger)
So, cutting the spring did not make a difference your saying... Which valve did you work on?
:crazy:
Old Jun 1, 2002 | 03:18 PM
NHVett's Avatar
NHVett
Cruise-In I Veteran
Default Fuel Tank Pressure - Not Normal
It is Not Normal!!!!!
You have a rusted closed fuel vapor line that runs beside the gas line from the tank to the vapor recovery tank up by the left headlight tub.
Run a search on "Tank Pressure"
Mine has been fixed, and I get only an occasional slight hiss when removing the gas cap.
Took me 6 hours to remove the line, rod out the rust particles and put it all back together.
[Modified by NHVett, 9:39 PM 6/2/2002]
To Fuel Tank Pressure
