Weird thing I discovered while doing my carpets
Old May 29, 2002 | 11:25 PM
thrills's Avatar
thrills
Moderatrix
Cruise-In IV Veteran
Default Weird thing I discovered while doing my carpets
The seatbelts don't match the car :eek: Better yet they don't match each other :crazy:
The part encased in this portion
does not match the car. One is red and one is grey :crazy:
BTW the ones that you pull across are blue, just not this part! Anyone else have this happen?
Old May 29, 2002 | 11:31 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Weird thing I discovered while doing my carpets (thrills)
I've heard of this happening before. I think it was mentioned quite a while back. Mine match :)
Old May 30, 2002 | 12:10 AM
Rob 93ZR-1's Avatar
Rob 93ZR-1
From: Fear causes hesitaiton...and hesitation will cause your worst fears to come true. Houston TX
Cruise-In VII Veteran
Default Re: Weird thing I discovered while doing my carpets (Mr Mojo)
:confused: Are you talking about the plastic seatbelt covers? I see no red, only gray and blue.
Old May 30, 2002 | 12:20 AM
Route66dan's Avatar
Route66dan
Jenn,
Did you replace the passenger side crash pad? It doesn't look like it's there in the pic. If you did, did you put a Corvette emblem on it? I made this change to the flat panel and like it, but it looks plain without a logo or lettering on it. Also, please let us know how the carpet job comes out when finished. My '85 will need it before too long.
Thanks,
Route66dan
Old May 30, 2002 | 07:13 AM
93 ragtop's Avatar
93 ragtop
I think GM had a recall on earlier c-4 seat belts. I wonder if they were replaced with the different ones at that time.
Old May 30, 2002 | 09:39 AM
your drinking buddy's Avatar
your drinking buddy
Cruise-In V Veteran
Cruise-In VI Veteran
Default Re: Weird thing I discovered while doing my carpets (Red 86 4+3)
I have a red one on the driver's side, not sure about the passenger. My interior is gray :cheers:
Mines a 91 too
[Modified by vettes rule, 8:40 AM 5/30/2002]
Old May 30, 2002 | 09:40 AM
thrills's Avatar
thrills
Moderatrix
Default Re: Weird thing I discovered while doing my carpets (Rob 91Z07)
Nope the plastic covers are blue, the nylon belts inside are what's odd colored!
I don't think there was ever any recall work, I have all of the paperwork on the car and I never saw that in the reciepts. Then again he might not have saved that.
Old May 30, 2002 | 09:48 AM
thrills's Avatar
thrills
Moderatrix
Default Re: Weird thing I discovered while doing my carpets (Route66dan)
Dan here are my progress threads, it's definatly a two day job.
day one http://forums.corvetteforum.com/zerothread?id=310165
day two http://forums.corvetteforum.com/zerothread?id=310690
I suggest that you check what else needs to be replaced while you have it apart, for example I had to replace the storage bin frame and doors. Also give yourself plenty of time, we cleaned each part as we took it off. This was stuff that had 18 years worth of sweat and grime :eek:
Email me if you have any specific questions about what we did. I feel like an expert now ;)
Old May 30, 2002 | 03:10 PM
B R's Avatar
B R
From: Los Angeles, CA.... I know a guy who has a Lambo with Corvette doors
What's the point in having seat belts when you don't have any SEATS? :lol:
[Modified by B R, 11:11 AM 5/30/2002]
Old May 30, 2002 | 03:17 PM
OrangeC4's Avatar
OrangeC4
Mine match, I think.
Old May 30, 2002 | 11:59 PM
bluevette87's Avatar
bluevette87
Default Re: Weird thing I discovered while doing my carpets (OrangeC4)
jenn,mine don't match either,the drivers side one is dark red the passenger side one is dark blue :yesnod:
Old May 31, 2002 | 12:07 AM
Bluewasp's Avatar
Bluewasp
NoVa Events Coordinator
St. Jude Donor '14
Default Re: Weird thing I discovered while doing my carpets (bluevette87)
mine don't match in my GS... the passenger side is this odd blue color...
Old May 31, 2002 | 12:08 AM
thrills's Avatar
thrills
Moderatrix
Strange huh? I guess they make good use of their scraps, lol!
Old May 31, 2002 | 12:11 AM
Juliet's Avatar
Juliet
They've been doing that for years Jenn. In 1970 the short belt piece alongside the trans tunnel is black for just about all interiors since it's covered by the plastic trim piece and not visible - until you get around to restoring the car! :yesnod: :smash:
To Weird thing I discovered while doing my carpets
