Maximum HP
Old Aug 11, 2012 | 04:40 AM
BullitVette's Avatar
BullitVette
Default Maximum HP
What is the maximum HP I can put on a 90 Vette drivetrain?
Old Aug 11, 2012 | 10:58 AM
dukeallen's Avatar
dukeallen
How much can you afford?
Old Aug 11, 2012 | 11:31 AM
Frizlefrak's Avatar
Frizlefrak
Fast. Cheap. Reliable.
Pick two.
Speed = $$$ How fast do you want to go?
All of the usual metaphors apply. What are your goals and intended use for the car?
Old Aug 11, 2012 | 12:07 PM
chatham's Avatar
chatham
i think his question is how much HP with the rest of the drive train take without breaking.
Old Aug 11, 2012 | 12:32 PM
ch@0s's Avatar
ch@0s
I'm about to test the stock D36 and drive train. I hear it starts breaking around 400 FWHP I should be putting down 380 RWHP or so.
OP what are you building? If you search there are many discussion about this. From what I have read it varies really on the condition of your drive train and how sticky your tires are. I'm only speaking about what I have read and not from personal experience so if i'm wrong please correct me.
Old Aug 11, 2012 | 12:53 PM
Paul Workman's Avatar
Paul Workman
Max torque is the question - not horsepower per se. Torque to fail (GM) specs for the various components like spindles, U-joint, differentials, etc might lead to more specific data.
From observation, it seems the ZF trans is near bullet proof - even with some big 427-441 inch motor kind of torque. On the other end of the spectrum is the spindles on the C4. A "few" serious C4 drag racers carry an extra spindle with them when they go to the strip to race. You hear about a spindle breaking on stock or mildly modded C4s. U-joints and differentials failing comes up as "hp" increases to 600 and beyond.
That said, you run up a stock motor to 5000 rpm and side-step the clutch (especially on slicks), and "anything goes"!!
P.
Old Aug 11, 2012 | 01:47 PM
BullitVette
The drivetrain will determine the cost of the engine. I don't want to build a 500hp engine, then start snapping the transmission and rearend...I have the ZF 6speed. What is the weak link in the drivetrain?
Old Aug 11, 2012 | 02:04 PM
ch@0s's Avatar
ch@0s
Some useful links
http://forums.corvetteforum.com/c4-t...er-limits.html
http://www.digitalcorvettes.com/foru...ad.php?t=69948
Old Aug 11, 2012 | 02:45 PM
383vett's Avatar
383vett
It really depends on what the car will be used for and how it will be driven. With stock street tires, a stock drivetrain will probably last with 600rwhp. Spinning tires don't break things. If you are going to run sticky tires at the drags with a manual, then you will have problems.
Old Aug 11, 2012 | 05:23 PM
Frizlefrak's Avatar
Frizlefrak
So determine the power level that will keep you happy and upgrade everything. Because really, if you build it any LESS than that, how long will you like it, and what will it THEN cost you to get it where you want? Do it the way you want the first time out.
Old Aug 12, 2012 | 01:06 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
If it's not going to include drag radials with hard launches...AND, you're using a shorter runnered intake (to create the HP at higher rpms), you're fine going for the 500 (even rwhp). As stated, the ZF/Dana44 combination can go higher.
You've also got some specific scenarios to help temper the response to your scenario. (Good thing people will provide answers -- hoping to hit the right one BEFORE you provide the correct specifics)
BTW...I'm thinking U-joints are the weakest link (in the Dana44/ZF combo), but I'm not at the track like other guys. Or, the clutch/FW -- if you're still running an OEM DMF. People have run DMFs over 500hp, but not many for a long time.
Old Aug 12, 2012 | 07:55 AM
Paul Workman
As I said, the stock spindles seem to be the most common failure item (on ZR-1s, anyway).
Al (holding the half shaft with the spindle sheared off) is installing a 33 spline spindle to go with his 441 LT5 - hopefully in time for the Crown Point Corvette Challenge on September 9th.
P.
Old Aug 12, 2012 | 01:47 PM
GREGGPENN's Avatar
GREGGPENN
That's interesting. Don't remember that splined piece on mine. Is that the nose-end or tail-end of the DS? Must be the diff end?
Old Aug 13, 2012 | 01:41 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
I read somewhere that 450 RWHP will live long and prosper, whereas 600 RWHP is a flash in the pan.
Old Aug 13, 2012 | 05:39 AM
Paul Workman
I should have been clearer...That is the half shaft wheel spindle - sheared right off at the shoulder - had to tap the splined piece out of the hub to install a fresh one. (Two guys brought spare spindles to the track that day, if that tells us anything about C4 drive train vulnerability.)
Al was running on some big drag radials (I wanna say BFG 335s at least), and the track was in perfect condition (read: sticky!). All our big inch LT5 guys bring either a spindle or a trailer with them to the track, when its "GO TIME"!
P.
To Maximum HP
