Won't start
Old Aug 14, 2012 | 07:00 PM
mrmemo's Avatar
mrmemo
Default Won't start
Just lately the C4 won't start at the worst times. It runs great but every now and then it just won't start. If I wait a few minutes it starts and runs great. I took it to a dealership and they can't find anything wrong other than wanting to swap out the computer because no lights come up on the dash. Is there any one out there having the same problem or that can help? 1996 LT1 auto trans
Old Aug 14, 2012 | 07:18 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Just a quick tip that will go a long ways when you request help with your car.
Not all C4's were created equal. They had a 13 year model run, so there are huge differences between a 1984 and 1996.
And since you don't list what year you have, it makes it hard for others to help you.
Always give as much detail as you can about your car.
Year, transmission, etc.
Old Aug 14, 2012 | 07:24 PM
SQUIRMIN VERMIN 84's Avatar
SQUIRMIN VERMIN 84
From: Supreme Soviet Peace-Loving Pipple's Kollektive of Seattle Wa
Do you know the year?
Old Aug 14, 2012 | 07:53 PM
hooked073's Avatar
hooked073
year and what do you mean wont start? does it turn over?
Old Aug 14, 2012 | 09:17 PM
mazdaverx7's Avatar
mazdaverx7
guess i can add more fuel to that description fire. add as many details as possible when asking technical questions about your C4. as RollaMo-LT4 said, there were many different versions available. the C4 went through three different intake and fuel systems:
84: L83 aka Crossifre
85-91: L98 aka Tune Port Injection
92-96 LT1
96 LT4 (optional engine only equipped with a 6spd manual trans and only available in 1996)
with each version came improvements and refinements.. and with those came more electronics and even more power.
Old Aug 15, 2012 | 10:27 AM
mrmemo's Avatar
mrmemo
Default won't start
Turns over just fine it just won't kick in. If I let it sit for about 5to 10 minutes it will start and run just fine.
Old Aug 15, 2012 | 10:28 AM
mrmemo's Avatar
mrmemo
Old Aug 15, 2012 | 10:29 AM
mrmemo's Avatar
mrmemo
Lt1 1996
Old Aug 15, 2012 | 10:30 AM
mrmemo's Avatar
mrmemo
thanks for the heads up. my car is a 96 LT1 with auto trans
Old Aug 15, 2012 | 12:44 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
A lot of this going around lately. Just read some of the recent threads involving no start issues, a lot of things you can check depending on your symptoms.
Old Aug 15, 2012 | 01:29 PM
sailorsteve's Avatar
sailorsteve
If the engine turns over but doesn't start, I would first try to determine if it is a spark or fuel issue. Spray a SMALL sniff of ether into the intake while cranking; if the engine starts or tries to, you have a fuel delivery problem. If this test produces nothing, you have a spark problem. After you do this, post up the results. Also, as always, doesn't hurt to pull codes. Your car needs a code reader to do it, but some chain auto parts stores will do it for you no charge.
Old Aug 15, 2012 | 01:44 PM
TTA579's Avatar
TTA579
Does the car not start after having been driven? You mention that the car starts after sitting for an additional 5-10 minutes.
It sounds like starter heat soak, but you said the car turns over?
It could also be a problem with your fuel pump, if you have a leak down condition in addition to the fuel pump delay after shut down might cause you to have zero fuel when restarting.
Unfortunately the duration of your problem (5-10 minutes as you indicated) doesn't allow you to perform a lot of diagnostic testing before the culprit disappears.
Old Aug 15, 2012 | 05:35 PM
mrmemo's Avatar
mrmemo
Default no start
Thanks I will try the sniff next time it does it. I have recently changed the fuel pump due to a pressure problem. It started just fine prior to the pump change. I probably should change it again. Could be plugs but it runs smooth when it runs.
Old Aug 15, 2012 | 07:12 PM
sailorsteve
The best strategy is not to change parts at random, hoping for a win. You are better off systematically diagnosing the problem, then you buy and install only the part(s) you need. There is plenty of knowledgeable help on CF. Once you are able to eliminate lack of either fuel or spark as the issue, you can go from there. Of course, with an intermittent, it is almost impossible to troubleshoot when the symptoms are not there. Post back with your progress!
To Won't start
