So which pump?
Old Aug 15, 2012 | 02:45 AM
Louiseven's Avatar
Louiseven
Default So which pump?
My 86 water pump has gone off. I have been pricing water pumps and the prices jump wildly. $140.00 for AC Delco up to $229.00 These prices are from the dealer and Corvette specialty places. Napa and other local parts places Non-Ac Delco or high performance, have been from $40.00 up to $80.00.
IF you replaced your Water pump what did you go with? Why? And How much? Thanks in advance.
Old Aug 15, 2012 | 06:37 AM
HlhnEast's Avatar
HlhnEast
Did you check rockauto.com? They handle a lot of a/c delco stuff.
Old Aug 15, 2012 | 08:39 AM
wilcar's Avatar
wilcar
Stewart has some high perf. aluminum pumps, think I paid around $100 for a stage 1 through amazon. Others go with a $40 pump.
Old Aug 15, 2012 | 09:09 AM
oldalaskaman's Avatar
oldalaskaman
edelbrock
Old Aug 16, 2012 | 01:05 AM
84wannabezo6's Avatar
84wannabezo6
edelbrock
Old Aug 16, 2012 | 11:51 AM
mtwoolford's Avatar
mtwoolford
I really believe that the increase in flow of a pump with a cast or machined impeller where the vanes are curved is well worth the money over the cheaper stamped sheet metal "paddle wheel" designs...especially if you are considering any type of a pulley "underdrive kit".
and despite what the parts listing may say (especially with cheaper pumps) make sure the shaft outer diameter matches the i.d. of the water pump pulley...corvettes typically use a larger shaft of 3/4 inch od, lesser pumps may have a 5/8" od.
I used a weiand team G pump on a VB Monza some years back...not an easy car to cool by any means...it allowed installing a system of under drive pulleys with no loss of coolong.
Old Aug 16, 2012 | 10:15 PM
SQUIRMIN VERMIN 84's Avatar
SQUIRMIN VERMIN 84
From: Supreme Soviet Peace-Loving Pipple's Kollektive of Seattle Wa
I got the Chicom Special and saved bigtime for my 84!
(some fitting required).....
Old Aug 18, 2012 | 02:35 AM
Louiseven's Avatar
Louiseven
Thanks all. I will give rockauto a try as well!
To So which pump?
