Ac outside temp location
Old Aug 20, 2012 | 08:27 AM
Rod LaLanne's Avatar
Rod LaLanne
Default Ac outside temp location
Found why ac was not working some nimrod cut the sensor of when they replaced the radiator, where should it be mounted?
rod
Old Aug 20, 2012 | 01:09 PM
BlackbirdZ07's Avatar
BlackbirdZ07
What year? On my old '92, and I think also on my '90 ZR-1, the sensor is in the opening for the radiator air inlet on the passenger side. It's down low so you have to stick your head under the front bumper and look at the inlet to the AC condensor and radiator. It's in a small black plastic housing with holes to allow air flow, mounted to the passenger side.
Old Aug 20, 2012 | 01:19 PM
Rod LaLanne
Thanks: Hopefully i can fit my big head (which oddly enough has grown since i bought this vette) under the bumper.
rod
Old Aug 20, 2012 | 01:21 PM
Rod LaLanne
Doh it's a 1986
To Ac outside temp location
