Bad Paint Chip
Old Aug 28, 2012 | 04:58 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
Default Bad Paint Chip
Have no clue what hit me. Never heard it.
Best repair option??
About 1/4 - 5/16 dia
Old Aug 28, 2012 | 05:07 PM
Sweet 90's Avatar
Sweet 90
Maybe try this guy, might be better than a repaint of the hood. Good luck
http://forums.corvetteforum.com/c4-g...paint-pen.html
Old Aug 28, 2012 | 07:27 PM
Paul Workman's Avatar
Paul Workman
I've fixed a bigger chip (dime size) with the Langka Kit. The hardest part may be finding some touch-up paint that is the right color. Worth a shot, and you may be as surprized as I was!
P.
Old Aug 28, 2012 | 08:40 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
That's going to take some filler to bring it up level with the paint. Then it's careful sanding, touch up paint, and touch up clear.
Or, you could just put an Edelbrock decal over it and tell everyone it's a race car. Or, one of those bullet-hole decals.
Old Aug 29, 2012 | 09:32 AM
dukeallen's Avatar
dukeallen
Or a real bullet hole and explain your car doesn't take any crap from a Prius
Old Aug 29, 2012 | 10:09 AM
24695bob's Avatar
24695bob
I would paint the area with 1 or 2 coats of the red color..let dry between coats..Then apply several (5 or 6) thin coats of clear (again let dry between coats) until the clear stands out above the chip area... then sand the clear flat with the surrounding area with 2000 grit wet sandpaper..and finish off by hand rubbing toothpaste over the area...
I've repaired many good sized chips this way and if you take your time it is very very hard or almost impossible to see where the chip was originally ... Base colao to match the paint then many thin coats of clear..
I (and several other Corvette Club members were) shown how to do this my a club member who has a auto body and paint shop and has painted more then a few dozen Bloomington Gold Corvettes..
Bob G.
Old Aug 29, 2012 | 11:29 AM
mickey5's Avatar
mickey5
Hi folks, I'm curious about the application of the color coat(s). Do you use a fine hair brush, an air brush or a squeegee? How do you prevent a raised ridge of paint around the perifery of the chip?
Old Aug 29, 2012 | 12:51 PM
Cruisinfanatic
Bob G.
Thanks. Sounds like a plan
Old Aug 29, 2012 | 06:22 PM
Paul Workman
Bob G.
Good to know, Bob. Any particlar toothpaste, or will just about any brand do?
P.
Old Aug 29, 2012 | 06:34 PM
Paul Workman
You missunderstand. What you want is the new paint to be proud of the surrounding painted surface so that you can sand the repair down to be flush with the origninal paint - not the other way around.
P.
Old Aug 30, 2012 | 12:25 PM
Cruisinfanatic
Bob G.
how do you sand it flat without risking going through the clear outside the chip?
Some kind of block?
Old Aug 30, 2012 | 01:10 PM
RUU's Avatar
RUU
Some kind of block?
Pink eraser works well & is a good size.
Old Sep 5, 2012 | 05:57 PM
Cruisinfanatic
Default An update
I've got the paint in and the clear built up.
Now how am I to sand it down without risking going through the clear around the repair.
Old Sep 5, 2012 | 09:57 PM
lonesomeloser's Avatar
lonesomeloser
You can use something like a flexible sanding block or a small piece of wood. Something that you can wrap the sand paper around. Make sure the paper is nice and wet and go very slowly. After a few strokes, dry it off and check your progress. You should be able to feel it with your fingertip. Also, the area that is sanded, should turn a uniform grey color. Try to view it from different angles, too. This has worked for me . I'm sure others will have different methods. Whatever gets the job done
Old Sep 6, 2012 | 10:47 AM
24695bob's Avatar
24695bob
I use a plastic bottle cap from a bottle of water as a sanding block and with 2000 grit paper and plenty of water you don't worry too much about the surrounding area..the scratches are easily removed with the toothpaste which must be like 4000 or finer grit
Bob G.
Old Sep 6, 2012 | 05:59 PM
corvette Stu's Avatar
corvette Stu
Solid colors are easy to fix, it's the metalic ones that can only be sprayed. I have a friend that uses a red Sharpie for 91 Bright Red.
Old Sep 8, 2012 | 09:56 AM
Cruisinfanatic
Default update
All done,
Not quite as good as I was hoping, but a lot better than before. The paint isn't exactly matching and there are white specks in it caused b..... no clue
during before sanding
Here's after
To Bad Paint Chip
