brake problem
Old Sep 2, 2012 | 06:02 PM
Pellno1's Avatar
Pellno1
Default brake problem
Hi
All the sudden I have to push really hard for the brakes to work on my 87 any suggestions?
Thanks Jim
Old Sep 2, 2012 | 07:37 PM
96 Vette CE's Avatar
96 Vette CE
Banned Loser
From: They say you learn from your mistakes, I must be a genius
2017 Corvette of the Year
2016 C4 of Year Finalist
Creator of the "Original" whining and crying thread
St. Jude Donor '14-'15-'16-'17
Sounds like you may have a problem with your brake booster.
Old Sep 2, 2012 | 08:22 PM
kerrynewman's Avatar
kerrynewman
While you are at it, replace your brake lines, (chassis to caliper, 4 of them). You are riding around on 25 year old rubber lines. They are cheap insurance.
Any "system" is only as strong as the weakest link....."olde chinse proverb me thinks"
CHEERS and have a good Labor Day ALL!
Old Sep 5, 2012 | 08:42 PM
beerme's Avatar
beerme
I have the same problem on my 87. I replaced the booster with one of the new "plastic" ones and it isn't any better. I also replaced all the old rubber brake lines with new SS lines.
I am starting to think it is a vacuum problem with the booster not getting enough vacuum and therefore you must force the pedal. It is only a guess and right now my engine is out of the car undergoing a mild rebuild.
Best of luck, as for my problem I will continue chasing it once I have a motor in my car again.
Old Sep 5, 2012 | 09:48 PM
383vett's Avatar
383vett
To brake problem
