Desktop Dyno ??
Old Sep 7, 2012 | 03:59 PM
red L98's Avatar
red L98
Default Desktop Dyno ??
Sup guys ,
anyone have a desktop dyno program they can plug my motor specs in and give an idea of the power this thing should make ?
Old Sep 7, 2012 | 04:05 PM
THE 383 admiral's Avatar
THE 383 admiral
You can do this online now days.. send me your complete cam specs. Head specs, compression, intake system with Carb or TB CFM
Old Sep 7, 2012 | 04:10 PM
red L98's Avatar
red L98
434CI
11.3
Reworked AFR 235 with a 2.63 CSA
Fully ported and plunum mod Super Vic 2 intake
264/274@50 .715/.725 lift 110LSA in @ 108 .015/.025lash
vacuum pump
1050 4150 prosystems carb
Compcam vibration 1" spacer
MagneFuel 1/2" anti-reversion plates
head Flow #
.100 77/57
.200 161/114
.300 228/167
.400 277/214
.500 303/229
.600 321/234
.700 335/235
.800 337/235
.900 342/235
1.00 346/235
The head were flowed on a 4.155 bore and the exhust was flowed with no pipe , The CSA was increased to 2.63 and air speed Avg was reduced from 340 FPS to 295 FPS Avg . The flow only dropped 3-4cfm at each lift with the intak bolted on ..
This is going in a 2800# C4 corvette , with a 4link setup , wishbone , antiroll bar , and coilovers all around
TH350 with transbreak
Coan 5500 stall
4.33 gears
29.5 Tire
Old Sep 7, 2012 | 04:19 PM
THE 383 admiral
You need the 4 advance deg as well
Old Sep 7, 2012 | 04:23 PM
red L98's Avatar
red L98
I can not find the damn cam card
Old Sep 7, 2012 | 04:34 PM
THE 383 admiral
Cam mfg site should have the specs online..
Also what CFM is that Carb.. site shows 780 - 1040 .. are you trying to sneek in 10 CFM.. lol
Old Sep 7, 2012 | 04:40 PM
red L98's Avatar
red L98
haha i guess i am .. i would look it up online but i dont have the grind # .. cam is already in the shortblock .
Old Sep 7, 2012 | 04:49 PM
THE 383 admiral
Also the cam RPM range.. 6,000?? Less, More.. you really need that cam part number..
A very quick assesment 510fwhp
Old Sep 7, 2012 | 04:53 PM
red L98's Avatar
red L98
3500-7000 rpm also 1 7/8 headers
To Desktop Dyno ??
