Two Questions
Old Sep 10, 2012 | 09:59 PM
black-93-coupe's Avatar
black-93-coupe
Default Two Questions
Can the amber light bulb in the rear view mirror be replaced. Mine used to work but I just had the rear view mirror out when I was working on the weatherstripping and when I was putting it back in I dropped the mirror and the light doesn't work anymore. Both white lights work fine.
Another thing I noticed is with my tachometer. When driving at a steady speed and when I hit a bump I notice the tach needle sway up and down with the movement of the car from hitting the dip/bump.
Thanks, John
Old Sep 10, 2012 | 11:07 PM
Z51JEFF's Avatar
Z51JEFF
It can be replace I believe,ask this over in the tech section and somebody will have an answer.
Old Sep 13, 2012 | 08:51 PM
black-93-coupe
Figured out how to change the light. The light assembly pops out from the bottom with a small screwdriver and the bulb is a #74 bulb. Going to post about the tach on tech forum.
To Two Questions
