I need C4 help!
Old Sep 16, 2012 | 12:34 PM
GaryRoe's Avatar
GaryRoe
Default I need C4 help!
Have had this car 4 years...put maybe 200 miles on it. Wife won't drive it because the instrument cluster and driver info won't light up...never did. Replaced the speedo cluster, still nothing. Bought a 3rd unit from a member here that was working when he contacted me, never worked in mine. I'm a big...OK, fat...guy and can't get into the dash very far. I understand the problem is a ground. Many have told me to solder a wire to the ground strip of the printed circuit...but I want it fixed correctly. Anyone have a PICTURE of where all the ground wires track to? Do I need to remove the complete dash? Thanks in advance.
Old Sep 16, 2012 | 01:06 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Is the panel working, just not lighting up? If all three have the same problem, I would suspect your problem lies elseware.
Old Sep 16, 2012 | 02:14 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
check fuses.
Then:
remove the dash cluster again, and when you get to the connectors, you need to check for a ground on plug B1. D1 is also a ground.
Any red, pink, or orange is switched or non switched battery volts.
use your meter.
For instance,
the red wires usually mean that a fusible link is in line with the battery, and it is hot all the time, for instance, head lights.
Pink wires usually indicate that the wires are turned on by the ignition switch, but may be controlled by something.
Orange wires usually mean that the wires are turned on by the ignition switch, but are controlled by a switch somewhere.
Most systems are powered, and are looking for a ground so that if there is a short out from the main place power comes in, it will not drain the battery, just that the appliance will be running.......like for instance your courtesy lights stay on all the time.
For your dash not to work, it could be something as simple as the headlight switch dim circuit is bad, a ground wire corroded, or a fusible link is blown or there aren't any bulbs in your digital dash that work. (possible that the previous owner took them out, thinking you would know enough to check those $15 bulbs.
Ask yourself what else doesn't work, and see if there is a commonality between them.
Old Sep 16, 2012 | 04:11 PM
Railroadman's Avatar
Railroadman
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
Fill out your profile so we at least know what year we're talking about.
Old Sep 18, 2012 | 06:52 AM
wbc4's Avatar
wbc4
If you still have any of the digital dash instrument clusters left over after you get it going, I would be interested in buying. This link is helpful.
http://batee.com/corvette/dcrg/repai...tor/repair.htm
Old Sep 18, 2012 | 12:49 PM
brent317's Avatar
brent317
I had a similar problem on my 95. I ended up replacing the battery . All was good then and still is 5 months later.
To I need C4 help!
