when i drive my car every now and then the car will stall, the car will start back up but this problem is getting very annoying someone told me it was a sensor on the side of the block and someone else told me it was the crank sensor. has anyone had this problem with a 84 corvette http://www.youtube.com/watch?v=XrAQNmmqYHY
I definetly wouldn't let that person touch your car.
When you go to restart it, does it help to step on the throttle? IOW, does it start more quickly with some throttle applied? Or not?
Can you remove the air cleaner and hand throttle it and watch what the injectors are doing?
I agree that it's not the Crank Sensor...since the car doesn't have one.
I agree that it COULD be the IAC's.
every now and then the car will cut off if i don't give it a little gas. if i drive alittle crazy and then try to drive normal it will most likely cut off. as you see in the video link it will cut off everytime i rev high
