Remember this device?????
Old Sep 19, 2012 | 07:53 PM
VETTEHIGH's Avatar
VETTEHIGH
Default Remember this device?????
Years ago Mid America had this device that you plug into your cig lighter and connected a 9V battery to it. This was used to save all data when you disconnected your battery. Is this still around or something close to it? Thanks
Old Sep 19, 2012 | 07:58 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
http://www.parts123.com/parts123/yb....Z5Z5Z50000050F
Old Sep 19, 2012 | 08:39 PM
QCVette's Avatar
QCVette
Active Streak: 90 Days
I think I got one a couple years ago from Walmart for about $5.
Old Sep 19, 2012 | 10:20 PM
Phat98's Avatar
Phat98
I've seen them in AutoZone, etc....
Old Sep 20, 2012 | 08:56 AM
VETTEHIGH's Avatar
VETTEHIGH
Thanks all for your help..........
Will they work for 6 months or so? My garage for the winter has no electric, but I will just disconnect the negative side.
Old Sep 20, 2012 | 09:17 AM
c4cruiser's Avatar
c4cruiser
No, the little 9v battery will not last more than a half-hour or so. The intent of that component is to save things like radio settings and ECM data while a battery is being exchanged.
Old Sep 20, 2012 | 09:48 AM
VETTEHIGH's Avatar
VETTEHIGH
So there is nothing I can do correct? Like I said, I wont be able to use the tender (no electric) and I do not want to take the battery completely out. Ideas?? Thanks
Old Sep 20, 2012 | 11:12 AM
mtnmanut's Avatar
mtnmanut
get a small battery charger solar panel harbor freight or 15.00-20.00
Old Sep 20, 2012 | 01:04 PM
shakedown067's Avatar
shakedown067
St. Jude Donor '12-'13
I say add solar power to the garage! http://www.harborfreight.com/45-watt...kit-68751.html
Old Sep 20, 2012 | 01:14 PM
Churchkey's Avatar
Churchkey
Can you charge it from your dd with jumper cables now & then?
Old Sep 26, 2012 | 10:05 AM
VETTEHIGH's Avatar
VETTEHIGH
My only options:
(1) Disconnect the negative and leave it....
(2) Remove the battery and store it......
Old Sep 26, 2012 | 10:09 AM
Frizlefrak's Avatar
Frizlefrak
With no load on the battery, this should keep it topped off....unless you live in Canada
Old Sep 26, 2012 | 02:07 PM
383vett's Avatar
383vett
Just make sure the battery is fully charged and disconnect the negative. You'll have to reset the clock and radio presets in the spring and your computer may need to relearn a few things, but it's not a big deal. Your battery will not run down and everything will be fine. You might want to take the battery out and recharge it once or twice out of the car.
Old Sep 26, 2012 | 07:18 PM
93Rubie's Avatar
93Rubie
I remove mine entirely from the car. I install (leave side panel off) once a month and run the car. No issues, just hook up the battery correctly, you won't hurt a thing.
I keep it topped off in my basement with a maintenance charger.
Driving the car a few times relearns all your fuel trims and things no big deal.
To Remember this device?????
