AC Conversion Question 1993
Old Sep 22, 2012 | 06:45 PM
chevyvette1's Avatar
chevyvette1
Default AC Conversion Question 1993
Anyone have any pics of the the locations where fittings get changed out AC upgrade? I have the new fittings and a someone who said they would change them for me for $30, I figure it shouldnt be that hard and save $30 little extra beer money
Old Sep 23, 2012 | 10:34 PM
1986coupe's Avatar
1986coupe
There are only a few that need to be done. Often the retro-fit ones simply screw onto the R12 ones. They are different sizes so you should be able to work through it.
Old Sep 24, 2012 | 03:38 AM
gerardvg's Avatar
gerardvg
Hi see the link below of the fittings that screw on to the old R12 access ports to update them to R134A first is for high side, second link for low side
http://www.ebay.com./itm/Charging-Po...item4845b12785
http://www.ebay.com./itm/Charging-Po...item4845c5b351
Old Sep 24, 2012 | 08:10 PM
chevyvette1
where are the fittings located under the hood? Pics? Thx
Old Sep 25, 2012 | 09:04 PM
miker2's Avatar
miker2
you have to remove the old schrader valves (valve stems ).one is standard size like in a tire.the other is larger and requires a different tool to remove.they're available on amazon or ebay.
Old Sep 26, 2012 | 12:55 PM
chevyvette1
looking for pics of the fittings that need to be changed plz
To AC Conversion Question 1993
