Stat stuck open?
Old Sep 30, 2012 | 10:44 AM
ScottMA64's Avatar
ScottMA64
Default Stat stuck open?
Hey everyone. Took a ride around the backroads of temecula and the palomar mtn area. It was a cool night, probably somewhere in the mid 60s. The roads have a 55mph speed limit. My temp readback on my '86 went as low as 144. It basically stayed around 150ish. Went I got back on the highway doing 70, it stay around 170.
Does this sound like a thermostat thats stuck open? Seems to run way too low.
Thanks!
Scott
Old Sep 30, 2012 | 01:23 PM
Keystring's Avatar
Keystring
I had the same thing when I got my 87.
Turned out it didn't have ANY thermostat.
Put in a 180 and all fixed..
Old Sep 30, 2012 | 03:06 PM
FOURSPEEDVETTE's Avatar
FOURSPEEDVETTE
If it ran at normal temps (185-225) before this and the problem just started, I'd bet on the t'stat being bad. The car would be fine with a 195 degree t'stat as I have in my 85. But many install a 180 degree t'stat trying to keep it cooler. ( P.S. Stay out of the hot stuff brother.)
Old Sep 30, 2012 | 07:33 PM
gunnerjuju's Avatar
gunnerjuju
Had this issue and both times it turned out to be the tstat
Old Sep 30, 2012 | 09:06 PM
ScottMA64's Avatar
ScottMA64
I've only had the car less than 2 weeks and last night was the 1st time i've drove it on a cool night. I thought it had a 170 or 180 in it cause thats where it generally was unless i was in stop and go traffic. Ok, i'll add tstat to the "to do" list lol
Scott
Old Oct 3, 2012 | 03:59 PM
ScottMA64's Avatar
ScottMA64
Well I found that there is a 160deg thermostat installed. I also checked the eeprom and it is stock. Shouldn't you update the prom if you go to something other than a stock stat? I bought a 180 to replace it.
Scott
Old Oct 4, 2012 | 02:26 PM
FOURSPEEDVETTE
You won't need to change anything if you stay with the 180 degree T'stat.
To Stat stuck open?
