90 right headlight
Old Oct 3, 2012 | 06:42 PM
mphy98's Avatar
mphy98
Default 90 right headlight
I have a right headlight that will not go up or down unless I power it to the motor itself. I replaced the headlight module 2 years ago when it did this with a used one that worked great. I took it out of storage last month and came home at night for the first time and it is doing it again. I am sure it is the module again, is there a way to jump it from one side to the ther just to make sure it is gone? any one have a wiring diagram with colors just in case? thanks bob
Old Oct 4, 2012 | 12:19 AM
oldalaskaman's Avatar
oldalaskaman
swap the plugs
Old Oct 4, 2012 | 12:29 AM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
You can tie the bad side to the good one, and it will work.
Old Oct 4, 2012 | 01:58 AM
oldalaskaman
if it goes up and down when you power the motor direct, its probly that used module
To 90 right headlight
