84 Brake Pressure Warning Switch
Old Oct 5, 2012 | 03:52 AM
jhimer's Avatar
jhimer
Default 84 Brake Pressure Warning Switch
Is there any way to check if this part is bad? I am trying to get my 84 back on the road. It has been sitting for a few years. I have it started and running. I have replaced the brake booster, MC, rotors, pads and flushed system. The brakes are solid. The dash Brake Warning light is on. The Warning switch is the original I moved from the old MC to the new. With switch removed the MC looks good. No brake fluid leaking from the switch. Valve in MC seems to be lined up. Just seems so expensive for a small part with a spring in it and difficult to locate.
Thanks,
John
Old Oct 5, 2012 | 04:33 AM
gerardvg's Avatar
gerardvg
The white brake warning switch on the master cylinder indicates if there is a brake pressure imbalance between the front and rear brakes.
If there is an imbalance the white spring loaded switch will contact the metal recess of the combination piston which is spring loaded so will stay in the failed position, i think you will need to bleed the front and rear brakes with it removed and refit when the bleeding is finished. Not 100% sure on this. Maybe removing the warning switch after bleeding the brakes will work.
The white brake warning switch is fairly in expensive was only a few dollars i think when i broke mine a year or so ago.
Good luck
Old Oct 6, 2012 | 03:34 AM
rodj's Avatar
rodj
With the switch removed from the M/c and connected can you make the light change by moving the plunger?
If not; switch is faulty.
If light goes off and on then brake system need rebalancing ,
Old Oct 8, 2012 | 02:06 PM
jhimer's Avatar
jhimer
Thanks,
Bought new switch will be here next week. Price ranges are crazy!!
$23.00-50.00
Will advise when installed.
John
Old Oct 9, 2012 | 12:41 AM
C4boy's Avatar
C4boy
You should be able to check the switch for continuity with an ohm meter. It completes the circuit to the dash light when the switch is grounded to the MC.
Old Oct 10, 2012 | 04:50 PM
jhimer's Avatar
jhimer
Default Fixed!
New Switch and I am Golden.
Thanks for all the help!
Old Nov 24, 2012 | 10:54 AM
jjaymoore's Avatar
jjaymoore
1st Gear
Where did you find this for the best price?
Old Nov 24, 2012 | 03:00 PM
jhimer's Avatar
jhimer
Oddly Amazon!
Fixed the problem.
John
Old Nov 25, 2012 | 06:29 PM
BSenzina's Avatar
BSenzina
Question for ya.....I have an 84......how do you feel about the stopping power on your 84??? Is it good ro marginal like mine??? Can you lock up teh brakes if you want to???
Old Nov 26, 2012 | 12:22 PM
jhimer's Avatar
jhimer
Haven't had it on the road yet. Had it around the block several times.
It stops well. No license plates yet. No hard stops, don't want to draw attention to it yet!
If yours doesn't stop, check the booster. Common failure!
John
Old Nov 26, 2012 | 01:20 PM
jhammons01's Avatar
jhammons01
Wow. learn something new everyday.....I've never seen this light before.
Old Nov 26, 2012 | 06:17 PM
BSenzina's Avatar
BSenzina
Booster is fine.....thanks tho
Old Jan 21, 2025 | 08:26 PM
LAR70455's Avatar
LAR70455
1st Gear
Where did you buy the brake pressure switch?
To 84 Brake Pressure Warning Switch
