cluster problem '86 vette
Old Oct 8, 2012 | 02:42 PM
ALG's Avatar
ALG
Default cluster problem '86 vette
I recently purchased a '86 corvette conv. I will post pictures as soon as i figure out how to post them.
Problem. The cluster is dim during the day and black at night. Also, the cruise control is not working. Could there be a problem affecting both?
Any suggestions on how to proceed? Thanks in advance.
Al
Old Oct 8, 2012 | 05:04 PM
corvetteharley's Avatar
corvetteharley
Just a thought if all guages are displaying correct readings the backlight bulbs might be bad.do turn signals light up when lever switched and does high beam indicator light when you switch it.if they do id think bulbs.if you take a flashlight and shine it on your instraments in top left corner (there is a photo cell that adjusts brightness of cluster so you can see during day) shine it there does it do anything.ive had bulbs burn out and dash goes dim but guages work thats my guess.
Old Oct 8, 2012 | 05:40 PM
ALG's Avatar
ALG
Yes the turn signals andlights light up. The flash light on sensor did not do asnything. As daylightgoes away so does display. Think it is the bulbs? Are they hard to change?
Old Oct 8, 2012 | 08:14 PM
corvetteharley
If you can see the readouts then my guess is bulbs.there are 4.thats just my thought others here might have better ideas.if you can wait a bit for others to reply you should.as far as changing them for me its not that bad.look in the i think help or tech area for help if nobody replies or you cant find anything write me back ill try and help if i can.
Old Oct 10, 2012 | 03:14 PM
corvetteharley
Did you fing anything out yet
Old Oct 10, 2012 | 03:38 PM
ALG's Avatar
ALG
Haven't had a chance to work on it yet. Maybe this weekend. I will let you know as soon as i get it out.
Old Oct 17, 2012 | 08:22 PM
ALG's Avatar
ALG
It was easy to get bulbs out. They ere all bad. Now I cannot find replacements. NAPA said they would order for me at $7.98 each. Are there any subistites for the 882 halogen? Also could not find 7073 Stanley bulb anywhere.
Any suggestions? Maybe NAPA is a good price?
Old Oct 17, 2012 | 09:02 PM
corvetteharley
Ive seen people here ask that before but i dont know the answer look in the help area you might find it there.i checked prices on ebay and think it was about the same.i paid to have mine fixed till my friend passed away.now i have to figure stuff out myself.my cluster went bad from water leak i tore everything apart and resoldered cluster boards its partially fixed.thats hiw i figured out how go change bulbs.whatever you get be sure not to touch bulbs with bare fingers the oil on your fingers will cause premature failure if you do touch wipe as clean as possible. If i find anything on type of replacements ill let you know.
Old Oct 17, 2012 | 11:11 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Napa is a good price. I have paid as much as $12 for one in a pinch.
Old Oct 19, 2012 | 06:52 PM
ALG's Avatar
ALG
I just bought 5 bulbs for $5.00 on amazon. they are halogen 12v g4base 5 watt. Picture looks the same. Think they will work?
To cluster problem '86 vette
