fuel pump sending unit
Old Oct 8, 2012 | 04:56 PM
glenn87's Avatar
glenn87
Default fuel pump sending unit
Hello everyone, I need a little knowledge. I have an 87 vette that has been sitting for two years. I put a new battery in it and it only turned over and would not start. I couldn't hear the fuel pump kick in and had no pressure at the fuel rail. I replaced the fuel filter and then got no fuel coming out of line when turning the key on. I have pulled the sending unit and fuel punp. Pumped out old gas in tank. I have a unit from an 89 with ahs a 4 prone plug. I was told it would work and just to spice my plug onto it. Is this correct. Thanks for your help
Old Oct 8, 2012 | 07:31 PM
Frizlefrak's Avatar
Frizlefrak
Yes. Ensure polarity is correct or the pump will die immediately.
