Gas mileage question
Old Oct 12, 2012 | 10:54 PM
Radar75's Avatar
Radar75
Default Gas mileage question
Earlier this week I accidentally killed my battery. Before it happened my average mileage was right around 17.5 mpg. Now it is down to 12.2. Is it normal for the car to do this after loosing the bat, and will it correct its self. My baby is a 1995 btw. Thanks in advance for any help.
Old Oct 13, 2012 | 01:13 AM
mustangsmoker's Avatar
mustangsmoker
Ya it resets itself I've done it a couple times with mine it'll go back up their in time
Old Oct 13, 2012 | 07:13 AM
WW7's Avatar
WW7
The ecm has to relearn everything, and until it does the car won't be running at its optimum efficency.. On mine it takes about 30-40 miles before its back to normal...WW
Old Oct 13, 2012 | 08:50 AM
bac22's Avatar
bac22
No...mileage shouldn't drop that much...if it doesn't resolve itself by next fill up, you've got another problem.
Old Oct 13, 2012 | 05:49 PM
Larry/car's Avatar
Larry/car
I'm surprised your only getting 17.5 mpg. My 1995 with the performance rear and auto trans gets around 20 mpg. I had a 1990 with the standard rear, auto and that car averaged around 22 mpg.
Old Oct 13, 2012 | 07:54 PM
VeryUnoriginal's Avatar
VeryUnoriginal
Whenever the battery is disconnected or dies the system resets. It's just like whenever you reset after a fill up.
Old Oct 13, 2012 | 08:25 PM
eutu1984's Avatar
eutu1984
2021 C4 of the Year - Modified Finalist
22 mpg is my average (mostly highway) and that's with bad injectors and a code 32 for the EGR, I hope to fix both this winter.
Old Oct 13, 2012 | 08:33 PM
VeryUnoriginal
My old 94 Camaro Z28 auto got 21 average. Is your Vette an auto? My '93 averages 24 or 25 with just about 80% highway mileage.
Old Oct 13, 2012 | 08:44 PM
eutu1984's Avatar
eutu1984
Yes my 90 C4 is an auto with stock gearing, 2.59 I think.
Old Nov 3, 2014 | 08:23 PM
BucfanTitan's Avatar
BucfanTitan
So if I am seeing low 17s and have an auto with 3.07 gears. What should I be looking for to correct this problem? I noticed since I changed the coolant my mpg has gone down. Before I was in the low 22 for an average.
Old Nov 5, 2014 | 11:36 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
If your driving the car to charge the battery, your overloading the alternator.
This can/will cause two undesirable results.
-Burn up the alternator due to overloading
-Burn up fuel while overloading the alternator
Always fully charge after killing the battery.
Old Nov 5, 2014 | 11:58 PM
C4C5C6's Avatar
C4C5C6
Default Fuel Mileage
I'm getting 17.5 around town.
1984. Engine stock original with 164,000 +/- miles on it.
I've owned it for the last 15 years and it's been very 'trouble free'.
Now that I've said that, the fuel pump or water pump or SOMETHING that pushes, pulls or rotates HAS to go out.
Oh well, it's a very simple fuel injection system that is easy to work on.
The rest of the '84 is easy to fix as well.
BTW it has the Z51 option. LOVE that quick steering ratio and the flat cornering. She really hooks you up with the road and drives like a go-kart.
How does my C6 get 22.5 around town with TWICE the HP?
Old Nov 6, 2014 | 12:04 PM
Paul Workman's Avatar
Paul Workman
Charging a dead batt is hell on the diode pack and windings (to less extent), especially in hot weather. Nothing like also replacing the pack or the entire alt. to add insult to injury!
To Gas mileage question
