4+3 swap
Old Oct 21, 2012 | 05:26 PM
DHobbs's Avatar
DHobbs
Default 4+3 swap
So I'm about 60-65% done. Trans is in looking good... only probably.. shifter. How is it mounted? I cut the hole but I don't see how it mounts. Any help?
Old Oct 21, 2012 | 09:49 PM
DHobbs's Avatar
DHobbs
Also what do I do about the plug that connects to the actual automatic shifter? Is there anything I have to do to the computer? Also. Does anyone have a picture of the manual shifter on?
Old Oct 22, 2012 | 12:06 AM
vetteoz's Avatar
vetteoz
You need to take the backup light wires through the floor to the backup switch on the trans
take the P/N wires to the clutch safety switch on clutch pedal
and make safe the org and black wires that told the computer if the trans was in gear or not
Old Oct 22, 2012 | 12:11 AM
vetteoz's Avatar
vetteoz
Shifter is mounted in a recess in the side of trans tunnel ; not to the trans as is normal
Do you have that section of tunnel glassed in as shown in bottom pic?
Old Oct 22, 2012 | 06:26 AM
DHobbs's Avatar
DHobbs
Those are perfect pictures. Exactly what I was looking for... only now I dont that section :/. Anyone have a spare
Old Oct 22, 2012 | 06:39 AM
DHobbs's Avatar
DHobbs
What do you mean by make safe? Also I appreciate all the help for sure!
Old Oct 22, 2012 | 05:09 PM
DHobbs's Avatar
DHobbs
Wow. I like that, only thing is wouldnt the shifter rotate slightly when in use? From the looks it looks like the shift is only held on by the one bolt?
Old Oct 22, 2012 | 05:11 PM
DHobbs's Avatar
DHobbs
Also... I dont have the hose that goes from the back of the transmission to the top. Is that necessary? What is it?
DHobbs's Avatar
DHobbs
Basically from the rear of the overdrive. Im certain you know which one I'm talking about.
Old Oct 22, 2012 | 06:06 PM
vetteoz's Avatar
vetteoz
Same as in stock mounting ;everything pivots around the bolt
You can see from previous pic up top there is only a thin metal brace on the outside to stop the shifter " leaning " over
If making a custom bracket you could easily fabricate something similar on the drv side of shifter ( a box around shifter ?)
if you wished to do so
Vent line
Could use any piece of hose run up high to achieve the same
Old Oct 23, 2012 | 08:06 PM
DHobbs's Avatar
DHobbs
Any chance I could get ahold of you to ask further questions? You seem like the man with the knowledge! Pm?
Old Oct 27, 2012 | 08:21 PM
project C4's Avatar
project C4
This was just a mockup but it shows where the shifter is located in relation to the transmission .
thought it could help some.
Old Oct 29, 2012 | 01:57 PM
DHobbs's Avatar
DHobbs
I did something more like with the bracket that came originally and bolting it to the 4 corners of fiberglass on the tunnel. I don't like it. Ill get a picture of it up but I'm waiting for the actual section in the mail.
Old Oct 31, 2012 | 06:04 PM
DHobbs's Avatar
DHobbs
On the connectors in the interior there is
black
Orange
Blue
Light green
Dark green
And yellow.
What exactly do each go to?
Old Nov 1, 2012 | 03:23 AM
DHobbs's Avatar
DHobbs
Anyone know the connector?
Old Nov 1, 2012 | 05:36 AM
DHobbs's Avatar
DHobbs
Actually let me be more specific. Its the automatic shifter connector. I was just wondering what each one goes to so I can wire it correctly
Old Nov 1, 2012 | 07:52 AM
vetteoz's Avatar
vetteoz
black
Orange
Not needed make safe
Blue
Light green
Backup lights
Dark green
And yellow.
Clutch switch
Refer my post # 3 above
To 4+3 swap
Old Nov 1, 2012 | 12:45 PM
DHobbs's Avatar
DHobbs
Your the best! Its been holding me up lol. Now all I have to do is get my new clutch master and should be done... Exciting!
Old Nov 2, 2012 | 01:43 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
you will have to change the chip if you want the computer to turn on and off the overdrive.
You can add a manual switch if you prefer to turn on the trans yourself.
I put one in my 57, and I have an arm relay that works off the ignition switch, and an engage relay that works off the off/on switch powered through the arm relay......
You will also have to add a wire to the computer plug on A7 to the overdrive relay. it should be tan with a black tracer.
Then you will have to have a engage switch that goes to ground, then to the computer on C7.
There are other wires, like the vehicle speed sensor and another ground.
Old Nov 2, 2012 | 06:31 AM
DHobbs's Avatar
DHobbs
I was just going to run the switch. No computer. So im assuming I just run a wire with a charge to the switch and the switch to the od? That's correct?
