Bat wing $
Old Oct 22, 2012 | 10:20 AM
DonF's Avatar
DonF
Default Bat wing $
I have a 345 rear end Bat wing a person I know is interested in buying it, what is it worth? This is a Dana 44 part # 605491 1990 -96 1/2 Thanks
Old Oct 22, 2012 | 11:58 AM
johnnymo63's Avatar
johnnymo63
2021 C4 of the Year - Modified Finalist
C4 of Year Finalist (appearance mods) 2019
Question; you say 3.45, that is the axle ratio, is this an entire rear end or just the batwing. (Item on the right in the pic.)
Old Oct 22, 2012 | 12:01 PM
DonF's Avatar
DonF
The rear end with the Bat wing attached, I used it for a while & then put another in with diff. gears. There is nothing wrong with this one, no noises.
Old Oct 22, 2012 | 12:47 PM
johnnymo63's Avatar
johnnymo63
Depending on mileage, they go for $650- $1,200.
Old Oct 22, 2012 | 12:48 PM
WVZR-1's Avatar
WVZR-1
605491 isn't a 3.45 "only" identifier. A 605491-3 would be an identifier for a 3.45 ratio.
Value would be dependent on miles, how long has it sat and in what kind of an environment. There could be a considerable swing in value depending upon those specifics. Assuming a person needs to do bearings, seals and a clutch pack maybe not as much as you'd like to think.
I wouldn't consider $650 for anything that has sat for a considerable period of time in a questionable environment.
Old Oct 22, 2012 | 01:39 PM
DonF's Avatar
DonF
OK thanks that gives me an idea. FYI it has sat indoors in my loft area at work covered & dry. Pulled it out of my car around three years ago no leaks at the time & still dry underneath where it has been stored.
Thanks again
Old Oct 23, 2012 | 02:23 PM
dizwiz24's Avatar
dizwiz24
I see those go for about $1k.
Remember the d44 is desireable (vs. D36 in autos)
Good luck
To Bat wing $
