idle misfire
Old Oct 30, 2012 | 12:35 PM
floridatim1234's Avatar
floridatim1234
1st Gear
Default idle misfire
the 89 runs just fine but has developed two glitches
1 at idle it is rough tune upped compression good but almost sounds like a misfire some times it is not as rough but never smooth ?????
2 the automatic transmission does not shift to overdrive it used to every other gear is there and strong ??????
THANKS HOPE THERE IS A SOLUTION THAT IS REASONABLE
Old Oct 30, 2012 | 02:40 PM
Joe C's Avatar
Joe C
the rough idle may be a result of the throttle body needing a good cleaning - especially the IAC valve and associated (idle) circuit. as far as the transmission, i'd double check the TV cable adjustment. start there - i would think that should clear up some of, if not all, of your issues.
