Under Hood Lights
Old Oct 31, 2012 | 10:23 PM
c-4guy's Avatar
c-4guy
Default Under Hood Lights
I have been searching for a good hour and not having much luck,,I am trying to get the under hood lights to work on my 96, the bulbs look good and they are both connected on each side.. The connector that is on the drivers side under the hood is plugged in to what looks like a emty socket.. If i unplug it and test the connector it has power, The wire running to the connector has a little tab on it that says fuse. The socket that it plugs into is fastened to the side marker light housing , but that looks empty, it;s like it is plugging into nothing. If I test the light housing connectors there is no power there... Any info would be great, thanks
Old Oct 31, 2012 | 11:02 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
The lights have a type of mercury switch in them, so they come on when the hood is raised and turn off as it goes down.
Each light plugs into a connector, so just follow the wiring down from the light and you'll see where the plugs are. Most people unplug them, so they can leave the hood up at shows without the lights staying on.
Here is a picture of the connector on the passenger side. One on the drivers side is similar.
Also as you found, there is a fuse holder. I have removed that fuse on mine to keep the lights off. They really are not much good anyway. LOL
Here is a picture of the fuse holder.
Old Oct 31, 2012 | 11:53 PM
1986coupe's Avatar
1986coupe
Has an aftermarket switch been installed?
Old Nov 1, 2012 | 08:07 AM
c-4guy's Avatar
c-4guy
The fuse holder on my 96 doesn't open, The plug that plugs into it has power when it is unpluged. I cant see anything inside the fuse holder.
Doesn't look like any aftermarket switch is installed ..
Old Nov 1, 2012 | 10:00 AM
RollaMo-LT4
Yes, the fuse holder will open.
That part I circled in yellow on my 2nd pic above.
And there should be a fuse inside. If not, then that is probably why your under hood lights won't come on.
As I said, quite a few people remove that fuse in order to keep the lights from staying on.
The hood lights will remain on as long as the hood is raised. They are not "smart lights" that go out after awhile.
The fuse inside the holder looks similar to this:
Old Nov 1, 2012 | 10:56 AM
c-4guy's Avatar
c-4guy
Heres a pic of mine, it says red fuse on the top, but it doesnt open, the plug to the right has power even when un plugged,,
Old Nov 1, 2012 | 11:15 AM
RollaMo-LT4
Ok, I don't know what to tell you then.
The fuse holder does open. I have a '96 also.
That cap on top flips open, and there should be a fuse inside.
If not, then all bets are off as to what someone might have done to it over the years.
Old Nov 1, 2012 | 11:37 AM
c-4guy's Avatar
c-4guy
Thanks for your help, I tried to get a real thin blade in there to open the top and it's smooth .. i also tried pushing from the inside with a screw driver to try and push the top open and know luck..
Old Nov 1, 2012 | 12:11 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Thanks for your help, I tried to get a real thin blade in there to open the top.
It should OPEN; put some PB Blaster on it (just a little) and try again....
Old Nov 1, 2012 | 12:16 PM
Silver96ce's Avatar
Silver96ce
That "plug" in your photo is the fuse holder - it holds a 10 amp blade fuse and then snaps into the cover marked "fuse". You''l notice the little blue tag on it. Since it is empty, I would suspect that is your problem.
Old Nov 1, 2012 | 12:32 PM
c-4guy's Avatar
c-4guy
Thank you very much Silver 96 CE, I put a fuse into the connector and the lights came on.. i thought the connector was supposed to connect to a fuse that was inside the cover that has red fuse on the top of it and have been trying to get the top of it to open,,with no luck..
Old Nov 1, 2012 | 12:39 PM
Silver96ce's Avatar
Silver96ce
You're welcome.
Old Nov 1, 2012 | 01:06 PM
Old Ben's Avatar
Old Ben
2017 C6 of Year Finalist
You need to check that the lights go out when you lower the hood. The previous owner may have removed the fuse due to a bad mercury switch.
Old Nov 1, 2012 | 01:12 PM
RollaMo-LT4
It's been so long since I had mine open I had forgotten how it worked.
Took some pics during lunch for you.
Edit: Looks like Silver96 beat me to it, and got you going.
Old Nov 1, 2012 | 02:01 PM
c-4guy's Avatar
c-4guy
Thank for your help ..
Old Nov 1, 2012 | 02:57 PM
c-4guy's Avatar
c-4guy
I checked to make sure that the lights go off and they do as soon as the hood starts down.. I will have to remember to take the fuse out if the hood is going to be up very long i'm sure they will run the battery down..
Thanks again..
Old Nov 1, 2012 | 05:07 PM
IAFF alumni's Avatar
IAFF alumni
Remove the bulb from one of those lights (be careful... the lenses are GLASS) and go to http://www.superbrightleds.com/cat/l...acement-bulbs/ and replace them with LED's.
Much brighter, and you can leave the hood open all day without running the battery down. I believe the bulbs are festoons.
To Under Hood Lights
Old Nov 1, 2012 | 05:50 PM
c-4guy's Avatar
c-4guy
I ordered the LED bulbs, thanks for the info..
Old Nov 2, 2012 | 10:03 AM
FOURSPEEDVETTE's Avatar
FOURSPEEDVETTE
I installed an in-line toggle switch right next to each light. They look like factory installed switchs. The stock light bulbs are not very bright or useful by any means. I like the idea of LEDs as previously mentioned. But really, when are you ever going to use these lights? Don't we all just use a drag light or the overhead lighting in the garage for repairs?
Old Nov 3, 2012 | 12:54 AM
Phat98's Avatar
Phat98
Thanks again..
After you take your car for its first wheel alignment the tech will come to you and say "dude, your battery is dead". You then ask him if he removed the fuse for the underhood lights...the look on his face is priceless.
Ask me how I know this....
