1987 plenum runners
Old Nov 3, 2012 | 09:45 PM
Rjf2134's Avatar
Rjf2134
Default 1987 plenum runners
I have now replaced the runner gaskets twice. I still have a vacuum leak on the intake manifold side of the left runner. I cannot find a torque for the mounting bolts. Is there any additive that I should use on the gaskets?
Any suggestion will be welcomed. Thanks, Ron
Old Nov 4, 2012 | 04:31 AM
Keystring's Avatar
Keystring
some specifications are in lb. ft., and some are in lb. in.
Manifold to Runner Bolts 25 lb. ft.
Runner to Manifold Bolts 25 lb. ft.
Fuel Rail Attaching Bolts 15 lb. ft.
Throttle Body Attaching Bolts 18 lb. ft.
Throttle Position Sensor 18 lb. in.
Idle Air Control Valve 13 lb. ft.
Throttle Body Coolant Plate 27 lb. in.
Throttle Body Cover Plate 30 lb. in.
Power Brake Vacuum Fitting 108 lb. in.
Fuel Line Nuts 20 lb. ft.
Fuel Tube Bracket Bolt 25 lb. ft.
Fuel Pressure Connection 115 lb. in.
Pressure Regulator Base to Rail 44 lb. in.
Pressure Regulator Bracket 44 lb. in.
Outlet Tube to R/H Rail Retainer 44 lb. in.
http://tpiparts.net/tpi_torque_specifications
Search
Old Nov 4, 2012 | 09:40 AM
Rjf2134's Avatar
Rjf2134
Thank you. This is very helpful
Ron
Old Nov 5, 2012 | 11:04 AM
Rjf2134's Avatar
Rjf2134
Default Runner gaskets
Ron
Should I install a gasket sealer on the runner gaskets? If so, what do you recommend?
Thanks for the help
Old Nov 5, 2012 | 01:30 PM
mcm95403's Avatar
mcm95403
Thanks for the help
If you want them to stick, Permatex 3H. It comes in a small bottle with a brush cap.
If you want to be able to re-use them, just use chapstick on them.
It's possible you're getting the wrong gaskets too. The early TPI is a little different from the later ones as far as EGR tubes go. Not sure if the gaskets are different for them or not, but I know the TPIS set that I bought for my Accel runners didn't fit well at all.
Old Nov 5, 2012 | 01:48 PM
TA's Avatar
TA
Is everything installed on the correct sides? Not sure about early TPIs, but on later years the runners, as well as gaskets are side specific. Installation on the wrong side can cause vacuum leaks.
Old Nov 5, 2012 | 04:31 PM
Rjf2134's Avatar
Rjf2134
Default 87 runners
I am certain they are installed the same way I removed them. the problem is on the left front runner / manifold side. When I spray either in this area the idle smooths out and idle increases. I am going to take a much closer look when I dismantle. I 'm wondering if a runner can warp resulting in a poor fit to the manifold. I will use the permatex as you suggested and double check the new gaskets for proper fit. Thank you very much for your input. If you think of anything else please let me know
Old Nov 5, 2012 | 05:38 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
The Right Stuff Gasket maker finally stopped the leaks on my valve covers!
It hardens up nicely and remains pliable.
A light film on both sides of the gasket maybe helpfull.
Old Nov 5, 2012 | 06:39 PM
Rjf2134's Avatar
Rjf2134
Thanks for the info. This has turned into a nightmare for me.
Ron
To 1987 plenum runners
