Cleaning wheels
Old Nov 10, 2012 | 06:30 PM
onDjuice's Avatar
onDjuice
Default Cleaning wheels
Well i've pulled my ccw off the vette and the back sides need cleaning. They were used when i got them and are pretty bad back there.
What stuff does the best job???
Old Nov 10, 2012 | 08:02 PM
JimmyS5600's Avatar
JimmyS5600
Active Streak: 90 Days
This my sound weird,but the last set of C4 wheels I did I used
foaming bathtub cleaner. Sprayed on and let it sit for a few
minutes. Then used a 3M pad to rub it in. Rinsed with water abd
they where nice and clean.
Old Nov 10, 2012 | 08:35 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
I don't usually let mine get too dirty but I simply take a soft brush and after I have scrubbed the sidewall of the tire with Wesley's bleche white I swirl some of the suds over onto the barrel and scrub it with the soft brush, BUT, my wheels are chrome. Whatever you decide to use, be sure the cleaner will not mar the highly polished surface. I think I would just try to use car wash soap first, then maybe tar remover.
Old Nov 10, 2012 | 11:07 PM
jhammons01's Avatar
jhammons01
Just did this on Thursday.....Scrubbed the inside with the usual subjects without very satisfactory results. I looked on the wife's laundry soap shelf and found powdered Super oxyclean.....why the hell not??
Sprinkled it on the sponge I was using and rubbed it in...worked like a charm...all the grime came right off.
Old Nov 11, 2012 | 07:56 AM
onDjuice's Avatar
onDjuice
Sprinkled it on the sponge I was using and rubbed it in...worked like a charm...all the grime game right off.
The wife uses that stuff i,ll give it a try.. Cheers
Old Nov 11, 2012 | 11:51 AM
jhammons01's Avatar
jhammons01
Understand, when I did mine, I pulled the wheels off....that is the only way to get the inside
Old Nov 11, 2012 | 12:07 PM
don hall's Avatar
don hall
Thanks for the tip....... tried Simple Green Degreaser and Stoner Degreaser........ nada, only removed the 'dust' ....... SuperOxy is next.
Old Nov 11, 2012 | 12:20 PM
don hall's Avatar
don hall
Going to try jacking and spinning the wheel ...... at 80, looking for any shortcut.
Old Nov 11, 2012 | 01:56 PM
Midnight 85
Once you do get them clean, pick up a small swiffer duster, they go right in between spokes etc. and get all the areas nice & clean again.
Old Nov 11, 2012 | 05:59 PM
CE1's Avatar
CE1
The wheel cleaner from Griot's works great.....
http://www.griotsgarage.com/product/...ortby=ourPicks
Old Nov 11, 2012 | 07:20 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
I use "Foaming Bubbles" and it works quite well for this.
Once you're done, wax the insides to make them easier to clean the next time.
Old Nov 11, 2012 | 07:28 PM
jhammons01's Avatar
jhammons01
unfortunately, taking them off "is" the shortcut....
And congrats on becoming an Octogenarian, I doubt I'll make it that far in life.
Yup....
Old Nov 11, 2012 | 08:01 PM
onDjuice's Avatar
onDjuice
Right you are sir.. My wheels are off the car..
Old Nov 11, 2012 | 09:27 PM
derekguzz's Avatar
derekguzz
I wold not advise putting oxiclean or any degreaser strait on your wheels. The finish will pit and destroy it self it self very fast. If you do, wax soon after..Why not just throw bleach on them as well while your at it.
Old Nov 12, 2012 | 12:30 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I like to use Simple Green. Works great with a 3M no scratch pad.
Old Nov 12, 2012 | 02:14 PM
jhammons01's Avatar
jhammons01
Are you thinking that these are polished wheels? Clear coat or paint is not going to be harmed by Oxiclean or bleach. If they are, there is more trouble than first imagined.
Oxiclean, rubbed on and then rinsed off is not going to damage anything painted unless you scrub it on while it is still an abrasive powder.
To Cleaning wheels
