temp on 84 crossfire
Old Nov 13, 2012 | 10:29 PM
R84CORVETTE's Avatar
R84CORVETTE
Default temp on 84 crossfire
THANKS FOR YOUR HELP took my 84 vette for ride to day the digital dash temp gauge said 217 degree it was 37 degrees outside ,what is high temp on them? thanks
Old Nov 13, 2012 | 10:36 PM
NuckinFutz93's Avatar
NuckinFutz93
Most C4's I've seen and owned ran around 200* unless somethings have been changed.
Old Nov 13, 2012 | 10:37 PM
jhammons01's Avatar
jhammons01
217 while in town or out on a freeway or highway??
217 in town is perfectly normal.
If that is highway temps, then you may have an issue. With air flowing across the radiator at 45mph+, you should see it drop so low that the thermostat closes.
Mine goes down to 176° before it stops.....
Old Nov 13, 2012 | 10:55 PM
R84CORVETTE
what degree of thermostat should be run? thanks
Old Nov 13, 2012 | 11:07 PM
Frizlefrak's Avatar
Frizlefrak
Remove the radiator and clean the front of it. It will have a ton of crap on the front of it. Your temps aren't far out of normal, but at 37 degrees ambient it should run cooler. It's really that cold in San Bernadino?
Old Nov 13, 2012 | 11:23 PM
R84CORVETTE
going about 45miles per hour up highway about five miles or so? it was about 37?
Old Nov 14, 2012 | 08:06 PM
BSenzina's Avatar
BSenzina
I AGREE ! ! ! With sucha a low ambient temp, it should run more like 190, give or take a little. I MIGHT get up that high at a long red light, but not running down the road.
Old Nov 14, 2012 | 08:27 PM
R84CORVETTE
what degree of thermostat should i replace with thank
Old Nov 14, 2012 | 08:47 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
195*.
Old Nov 14, 2012 | 11:03 PM
mustangsmoker's Avatar
mustangsmoker
My car very rarely gets above 210 highway or city but I have a toggle switch hooked up n I run my fan the whole time I'm driving
Old Nov 15, 2012 | 08:54 PM
BradenJL865's Avatar
BradenJL865
If I have to stop at a red light mine hits 200-220 / But just rolling down the road its about 195ish.
Old Nov 15, 2012 | 09:19 PM
R84CORVETTE
hi, how did you hook that up thanks
To temp on 84 crossfire
