93 lt1
Old Nov 18, 2012 | 09:34 AM
kipling's Avatar
kipling
3rd Gear
Default 93 lt1
My 93 corvette coupe with 30,000 miles was running great. I turned the car off and it sat for about a half hour and after starting it again the car ran rough and started to backfire.
Old Nov 18, 2012 | 08:30 PM
vetteoz's Avatar
vetteoz
More info needed
At idle , while driving , under load.......????
Have you pulled the engine codes to see if any faults are showing?
Old Nov 20, 2012 | 01:05 PM
kipling's Avatar
kipling
3rd Gear
Did not pull any engine codes, just placed the car in storage for the winter. A couple of friends mentioned that it may be the optic iginition unit, the C4 is noted for this problem.
Old Nov 20, 2012 | 01:11 PM
markKlein's Avatar
markKlein
The Optispark usually works great until you get it wet. Did you wash off the engine?
To 93 lt1
